#397852 05/01/02 04:09 AM
just picked up my g-tech pro, i know it may not be compare to being at a track. but i think it will be good to prepare for the track and judge modifications.
anyways i ran 16.13@90.3MPH so far
what do you guys think? ok for an auto?
any one elses times?
smile
Black '98 Mystique V6 atx. superchip,2 1/4" SVT style dual exhaust (custom) with no cat, high flow res, flo-pro mufflers with Ractive tips, 8.5" K&N conical with CTA adapter, UR Ultra Street Pulley, TH-fix. 215/45/17 Bridgestone RE730's on Konig Absolute wheels. Trans go Shift Kit, High stall torgue convertor, 24000 BTU transmission cooler.
#397853 05/01/02 08:57 PM
ummm, yep thats pretty damn good.
I dont know how accurate the g-tech is. But it should give you an idea. Take it to the track so you'll know for sure.
-neal
99 SVT...modified
96 GL....the beater
"I live my life a quarter mile at a time. For those 14 to 15 seconds, 16 if I get tire spin, or get a bad jump, or possibly if I have a friend in the car, I'm free."
#397854 05/02/02 02:46 PM
Average your times over five runs and make sure you calibrate it correctly! Call G-Tech they can give you a few more pointers on how to get it to work right.
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
#397855 05/02/02 03:17 PM
G-tech are normally within a tenth or two with the ET measurement and within 3-5 MPH with the MPH measurement.
Not bad.
1999 Mustang V6 5 speed
Mods-K&N filter, syn engine oil, removed spare tire & jack
Best ET-15.358@89.47 MPH w/ 2.227 60'
Best MPH-15.364@90.92 MPH w/ 2.383 60'
Will run better next time out, will not have snow tires on
1996 Camaro Z28 NA BFG DR's
60'-1.634, 1/8-7.563@89.82mph, 1/4-11.865@113.52mph
BEST MPH 1/8-90.73, 1/4-114.82
2002 goal - mid 11's@117-118mph NA, mid 10's@131-133mph n2o
#397856 05/03/02 03:27 AM
Provided you do 3 runs each way (6 total) and average them.
You CAN NOT just run one direction and call it accurate.
I agree they normally are within 1-2 tenths (under) and over-rate by 4+ mph
2000 SVT #674 - Check it out!
Moderated by  mbb41_dup1
