Posts: 19 |
I only know of one place that does Dyno tests near me, and I've heard that the other services they provide are overpriced, so I was wondering what price range is normal and what would be too high? Thanks.
98 contour SE 2.5L MTX resonator removed, sho shop cold air intake, arospeed muffler, painted center ring with grill insert, painted interior pieces, clear side markers, debadged and dingless.
Posts: 3,421 |
$65-100 this is with Air fuel.
Posts: 1,071 |
The dyno I go to is:
$45 to hook up the car and 3 runs $20 for heated wideband O2 sensor $50/hour If you want to make more than 3 runs.
Speed kills, but it beats going slow! Simon Langley Black 98 SVT EO (#2119 of 6535) 269.3 FWHP, 195.4 TQ 14.123 @ 97.36 All go, and no show! Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust. CDW-27 1/4 Mile Registry
Posts: 176 |
How much does it cost to buy a dyno? $10,000, 100,000 ??? Not that anyone could set it up with out the proper shop and stuff but I'm just curious.
2000 Roush Cougar MTX MSDS Headers, Rear disc conversion, SVT TB and IM, Custom 2.5" exhaust, Weapon R Dragon w/kkm MAF adaptor, B&M, NR wht gauges
Posts: 264 |
There's a lot of factors in deciding how much the Dynamometer costs. The 4wd/awd is where the extra added punch is, but for a regular 2wd dyno they start at around 24k. For a 4wd/awd one they start around 60k.
Tim '00 SVT
Posts: 1,682 |
Originally posted by kinger: How much does it cost to buy a dyno? $10,000, 100,000 ??? Not that anyone could set it up with out the proper shop and stuff but I'm just curious. you could put a dyno in your backyard, garage, anywhere you can lay enough concrete to hold a car, and dig atleast 6 feet into the ground.
Posts: 176 |
Mmmm....24K....located equadistant between Minneapolis and Des Moines....$100/hr...payback in 240 hours...mmmmm Buisness investment and fun toy to play with Thanks for the info guys
