Posts: 100 |
A made a few runs at the local dragstrip today. I think my car is low on horse power judging from my low trap speeds. My highest trap speed was 87.3 mph. But that was my slowest quarter with a 16.388. I only got down to a 15.889 @ 86.3. I just think that my car should run faster mph since it has headers. I am definitly going to clean out the intake runners at least.
1998 SVT #95: Toreador Red - SHM headers,K&N Filter, Energy Suspension MM inserts, Cross Drilled Rotors,Redline Tranny Fluid, Custom Billet Aluminum Shift Knob
Posts: 42 |
Sounds like you just need to work on your shifting and maybe the launch.
Diggs 99 SVT Green/Tan basically stock
Posts: 100 |
I thought my launches were pretty decent with a 2200-2500 launch by slipping the clutch a little and getting a little wheel spin but does shifting hard and fast really make much of a difference. I just really dont want to break anything. My shifts were pretty quick just no power shifting or anything. So does the launch help with the trap speed a good deal?
Posts: 157 |
shifting does make a huge time change. I shift so hard that I have broken 2 tranny mounts the shift housing and shattered the clutch. but with the up graded flywheel and clutch it grabs harder and faster. just try to take it easy on the down shifts, the up shift should be fine hard!
98csvt(red)white 19''Axis se7ens on toyo 225/35/19's injen intake,cust exhaust, High Rev's racing clutch,and flywheel .whatever its takes to run 12's (system)Eclipse 5442,Boston 6 1/2" pros, Eclipse 5x7 point scourse,PPIpc4400,PPIpc2600(chrome),power cap,2 12"JLW6 YOU WILL RESPECT THE FAMILY CAR
Posts: 86 |
i went to the track yesterday too...i ran a 15.9 at 89 mph and a 15.84 at ???(damn guy was changing the paper in the printer) shifting harder does make a little difference. first run i launched at 2500 and was shifting a little easier than i should have. second run i launched a 3000 and was shifting harder. i'm running with everything on my sig. but the chip and exhuast...basically stock. have one question? another ceg'r told me that shifting from first to second around 5200 is better for our car. is this true...the way he put it makes a lot of sense. thanks.
99' black svt #646 of 2760 born: 12-7-98
mods: kkm intake, mystery mod, bassani exhuast, sho shop pulleys, bosch +4, magnecor wires, superchip(sitting in my glove box), h & r springs, ebc gas-slotted rotors, luks super white bulbs(head lights), removed orange reflectors, removed ding guards, pre 98 sail panels, fog light fix, th fix i'm 1/3 of the CSVT's in my family
Posts: 100 |
I wouldnt think that shifting early in first would be faster because you would jump way below the power band in second. My second run I smoked the tires without realize how much they were spinning. My shift into second bogged down and I went a 16.3 but had my highest trap speed of 87.3 on that run which was a little weird.
Posts: 724 |
BIGJAy, why do you continue to post, they are typically so moronic and useless no one pays attetion to them anymore.
Im mean today
98 V6 Lots-o-mods SOLD 88 Daytona Shelby Z TII (The beast) 87 Daytona Shelby Z TII (Holy 20 psi of boost batman!) Mods- 3" Downpipe, Hi-Flow cat, 3" mandrel bent exhaust with Dynomax Ultra flow. Manual boost controller, TurboXS blowoff, 5th injector, large canister wastegate, Nitrous Express go-fast-be-happy kit, ported exhaust manifold, ported intake manifold, upgraded motormounts, eibach springs, strut tower brace. Oh and 20 PSI to boot.. my oh my...
Posts: 3,223 |
If you launching below 3g's I see why!
I launch from a minimum of 3gs up to 3.5. Sliding the clutch quickly! I can't seem to break 90 though! My best is in my sig!
-Andy
