#397095 02/26/02 07:09 PM
dubkatz Offline OP
What is the best launching technique? some wheelspin, no wheelspin,?
98 csvt, no res, bm shifter, sho-shop intake.
"wherever you go there you are"
#397096 02/26/02 08:46 PM
Not bogging the engine.
Minimal wheelspin.
NO wheel hop.
The easiest is a quick slip from around 3000 rpm.
2000 SVT #674 - Check it out!
#397097 02/26/02 09:36 PM
KJ Offline
Like Demon said ... My best launch to date was from 3500, 20lbs in the tires, and no wheelspin/hop.
Married the gal of my dreams 04.27.02 smile
2K SVT Black/Midnight Blue
#294 of 2150
DOB 10.29.99
kbucy@fbr.com
ktigerj on aim
A *few* Mods
Best Time 14.942 at 93.98mph
Car is now for sale - 14000
#397098 02/27/02 05:24 AM
I agree here also. I launch around 3500 with about 18 psi in my drag radials. God I can`t wait for the warmer weather. wink
14.72@ 92.6 mph
www.modularV8.com
"CLUTCH KILLER" and also recently known as the DRIVETRAIN KILLER
#397099 02/27/02 05:41 AM
What size tires do you use on the front? Are they on the factory rims? I want to pick up a set for my 95 once it is complete, just wondering what works for you.
#397100 02/27/02 07:02 AM
My best 60' is a 2.04 and that is with 32 lbs in my drag radials leaving at 5500 and no clutch slip or wheel spin. If you get good enough traction at 5500 the engine will still bog a little, I tried 6000 rpm and ended up spinning the tires. The only way to launch very well is with good tires but if you have a stock differential I wouldn't do it.
99 T-Red SVT #1634/2760
K&N filter
Aussie Intake Pipe
Pro-M 75mm & Optimizer
B&M Edge Shifter
Quaife LSD
Borla Cat back
MSDS Headers/sho-shop Y-Pipe
Dynoed at 184.2 HP & 157.2 TQ
14.53@94.15
#397101 02/27/02 08:09 AM
QUAIFE!!!
Oh... You mentioned something about that... wink
For the record I run with full air pressure. (35psi)
Less rolling resistance and the fact that lowering the pressure of "low profile street radial tires" is not going to help your contact patch any...
#397102 02/27/02 02:08 PM
I a not sure the exact size of the dr`s, but they are the factory rims on the front and "skinnies" on the rear. I will find out and let you know.
14.72@ 92.6 mph
www.modularV8.com
#397103 03/03/02 01:16 AM
Demon,
Do you use the stock g-force tires? If so how do you not spin off the line? I am usually racing on the street from a light and I spin through first. Launching at 3k to 3200 RPMs, this seems to give me the quickest launch though.
So any other thoughts on how to leave the line on the street with minimal tire spin?
2000 Black SVT
SHO y-pipe / hi-flow cat
Large Cone Filter
B&M shifter
C&L 73 MAF
Pro-Flow Optimizer
Magnaflow Res
BAT Intake
Always looking forward to beating those coffee can wanna-be-fast imports.
Douchebag Racing: You dont need a racing team and trailer for a 14 sec. car.
Check it out: www.geocities.com/jcs9614
#397104 03/03/02 07:54 AM
I'm a little mean to my poor clutch.
A little slip my be great on a woman, but it's a bit hard on the clutch. wink
Yes wheel spin can be a problem, but bogging the engine is worse...
Actually launching from about 2500 is the easiest. Minimal spin, easily controllable and consistent 60' times even though not stellar (2.3 range)
Slipping from high rpm's will generate better times, but it's very easy to blow right through the tires.
Modulating the clutch & pedal is the way to launch a FWD (or cornering even)
I highly recommend the ES trans insert & filled motor mounts to help with drivetrain wind up and consistency...
I also recommend full air pressure. Rolling resistance is your enemy...
Dropping your air pressure will not help the tires hook up better. The fact it's FWD (no weight transfer), stiff sidewall (heck the KDW's are self supporting run flat - they'll never bow/ripple), and low profile street radials = no benefits...
Moderated by  mbb41_dup1
