Posts: 377 |
Well, i washed my engine last night at the local carwash. I got in and drove it back home, ran fine but it though and engine code. So i get home and put the code reader on it. It gives me a cannot control idle at high RPMs and Cannot control idle at low RPMS. Then it gives me something about the fuel pump circuts. This is all about an hour later i start the car and it starts then cuts off. Then i go and start it again and it just cranks and crank. I look around under the hood and see nothing out of the ordinary. I go back and it starts so i rev it a little and it sounds find. Then i go to let it idle again and it drops to like 400 or 500 RPMs and then cuts off. So i try to start it agian, it just cranks. I stop for about 5 minutes and go back and it starts right up, so i rev it agian and then i try to let it idle and it just cuts off. I went though that processs for an hour then i give up on it. So i help finish putting the body kit on my friends CRX. Then like 2 hours later i go back and it starts up and runs fine. But i still have a sputter around three grand and my whole car shakes at idle.....Anyone had this or have any ideas?
95 SE MTX Throttle Hang Fix Fogs come one with Parking lights Custom exhaust(no res) 17" White Axis Touring Cup Perili P7000 Supersports KKM Sport Induction Windows tinted 15% EIBACH Springs Superchip New clutch @ 113k Quaife LSD Fidanza Flywheel White Faced Gauges BAT intake pipe I did have the Juice Poor excuse for a car owner =o( IbeKrusty@aol.com
Posts: 753 |
Originally posted by ContoursKickAss: Well, i washed my engine last night at the local carwash. I got in and drove it back home, ran fine but it though and engine code. So i get home and put the code reader on it. It gives me a cannot control idle at high RPMs and Cannot control idle at low RPMS. Then it gives me something about the fuel pump circuts. This is all about an hour later i start the car and it starts then cuts off. Then i go and start it again and it just cranks and crank. I look around under the hood and see nothing out of the ordinary. I go back and it starts so i rev it a little and it sounds find. Then i go to let it idle again and it drops to like 400 or 500 RPMs and then cuts off. So i try to start it agian, it just cranks. I stop for about 5 minutes and go back and it starts right up, so i rev it agian and then i try to let it idle and it just cuts off. I went though that processs for an hour then i give up on it. So i help finish putting the body kit on my friends CRX. Then like 2 hours later i go back and it starts up and runs fine. But i still have a sputter around three grand and my whole car shakes at idle.....Anyone had this or have any ideas? Water in the coil pack connections?
Posts: 1,421 |
or in the plug holes shorting it out
97 gsxr lotsa good stuff 4 sale 95 talon tsi awd turbo loaded sold 95 se 2.5 mtx loaded (fragile handle with care)2 motors 3 trannies custom y with hi flo cat,custom dynomax exhaust,upper cat mod superchip,udp,bat\kkm,proflow maf,ford 9mm wires,svt throttle body,svt intake manifold ,custom kevlar clutch,16 pd. flywheel,svt motor mounts ,svt gauges,eibachs\h&r,omp strut brace,dark chrome 16" rials with 225/50 dunlops,cwazy amounts of audio
Posts: 1,086 |
ContoursKickAss, I've washed my SVT's engine several times, just last Saturday in fact, & have not had any starting or running problems.
As ScottK & el contouro mentioned, the most likely culprit is moisture inside an electrical connector or device. I assume you used a high-pressure water wand or similar apparatus to clean your engine, hence the likelihood of moisture penetration is increased compared to just using a garden hose as I do.
Another possibility is the high-pressure may have caused a vacuum or other hose to become loose which may create some kind of air leak that your EEC computer is attempting to compensate but does not show up as a trouble code.
I had this happen on my Saleen Mustang one time when for some inexplicable reason it would not maintain a steady idle & would constantly stall. After several agonizing attempts to isolate the cause, I finally traced it to a flexible connector between my supercharger's discharge tube & the throttle body inlet. There was just enough of a mismatch between the two that it wasn't readily apparent to a cursory inspection, but it was enough to allow the pressurized air to escape, causing the computer to go a bit zany. Once I realigned the connector & tightened it, the idle returned to normal.
I'd suggest looking closely under your hood for loose connectors, hoses & any residual moisture.
1999 SVT Contour, #2140 of 2760, Tropic Green - Medium Prairie Tan Koni Sport struts; TSW Blade wheels; Nakamichi, a/d/s/, Boston Acoustics, Infinity I.C.E.
1989 Saleen Mustang, #89-0408, too many mods to list here
Posts: 1,537 |
Hey ContoursKickAss,
Get yourself a can of carburetor cleaner that comes with a straw. After starting your engine, spray some short bursts around the areas where different parts mate, like the Mass Air Flow to the Manifold, Upper/Lower Manifold, Injector/manifold area, EGR mounting, Idle Air Control mounting, etc. Any vacuum leaks will result in an IMMEDIATE increase in idle when you spray the carburetor cleaner. This is how you find an air leak.
For Electrical - Take your plugs wires and give both ends a good filling of Silicone Grease. Any electrical connectors that do NOT have weatherproof seals can also get a douse of Silicone grease.
If these don't solve your problem, I suggest you take it to a dealer, and tell them what your car is doing and DON'T MENTION that you POWERWASHED the engine.
Pete...
Pete... 98.5 SE Sport Duratec ATX (P66L) Black Clearcoat on Greystone DOB 11/21/1997 DOP 12/25/1997 PIAA 510 Super White Driving Lights SVT CAT-BACK EXHAUST (No Resonator) DiabloSport Chip (LPQ4) - Engineered To Raise Hell Too many other mods to list... Sounds sweet, runs quick... Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
