N
NITROS Offline OP
N
well, since im in need of a new suspension, and i would perfer a upgrade. i know i need the struts and springs. i always thought that if i have the combo of struts and springs, it would be finen.but i was talking to some 1 about this and they told me, that i need something more then that, he didnt know what. he said its not a direct swap. so some 1 more knowledgable then i please tell me what i need. i found something in search but didnt really answer my question
Experience is the worst teacher; it gives the test before presenting the lesson.
"You peel my onion down to the nun" - Gene Hackman [Under Suspicion]
-Walter-
96 Contour LX
The front struts are different in the way that they seat the springs. You can use the 98 and newer struts as long as you use the 98 and newer springs. The rear struts are interchangable. between the early and late cars.
To use the SVT suspension you would need front and rear struts and springs as well as front and rear sway bars and the necessary sway bar bushings to match.
You should be aware though, that the 95 to 97 SE suspension is stiffer than the SVT and might be a better choice if you are trying to make the car handle better.
There has been a lot of discussion over the years about the interchangability of suspension parts and you should be able to learn a great deal from reading some earlier posts and from reading the FAQs. You will also find some interesting information from the BAT catalog. www.batinc.net
Jim Johnson
98 SVT
N
NITROS Offline OP
N
thx alot for your help
-Walter-
96 Contour LX
