Posts: 1,268 |
larsofvt, IIRC, you can use late springs if you also install late struts.
-Ken V. psycho_bass@hotmail.com My Car
Posts: 14 |
For cougars roush and eibach are both made to be used with stock struts. From what I heard years ago they Are eibachs just wound a little different which makes em stiffer. Also I dont remember but one was progressive and the other was linear...anyone clarify? Also the differences between the 2 are probably not that noticeable- people love both. I thoght stock cougars sat an inch lower than contours to begin with, and some people on this board swapped with stock cougar springs? Like any lowering spring they wear out the shocks a lot faster.
Posts: 138 |
I talked with Roush and they said they didn't know if these Couger springs would work for a contour. And he said they have several left in stock.
Posts: 407 |
Originally posted by 4mula1: LBVSVT: Can you give us an idea how the Roush/KYB combo rides compared to stock? I am also concidering the KYB option. Thanks for any info. When I first put them on they were great on smooth surfaces, but rather stiff over bad surfaces. I had been running the tires at 36 psi, so I reduced it to 32 psi and it's now much better. Still stiffer than stock mind you and sometimes I wished I'd spent the extra money on the BAT matched kit. Another option is going to a softer or adjustable strut ala Koni (mucho $ though). Also, you'll get more bouncy with this setup, but again not too much.
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
Posts: 94 |
Got my roush springs today, now just waiting on my Konis!!!
Black '98 Contour SVT #162 of 6535 -Indiglo Gauge cluster- -Kenwood KDC-X815- -Audiobahn ALUM12x sub- -Audibahn 18001d Digital Amp- -Audiobahn 1.0 farad cap- -LED side markers/washer nozzels- -KKM Intake - Bosch Plat. +4- -Custom Exhaust - NO res.- -Sho Shop off road Y-pipe- -Fog light fix - THX-Fix- -Koni strurts - Roush springs-
Posts: 1,268 |
Got my roush springs today, now just waiting on my Konis!!! Hey! I ordered mine first! :p I better see the UPS man at my door soon
Posts: 1,268 |
Just got home. They arrived!! WOOHOO!! Finally, my 'tour will have a proper altitude adjustment. Now I just have to beg and plead my buddy to install them this weekend.
Posts: 94 |
It will be next weekend for me, thats not right!
Posts: 1,268 |
It will be next weekend for me, thats not right! Hee hee. Plus I get my SVT exhaust installed Friday. Im having a good week.
Posts: 94 |
CRZYDRVR did you get yours on yet, how do they look? I won't have mine on till next weekend Mat
