Madic Offline OP
I was wondering if my 2000 SVT Springs and Struts would bolt on any year Contour? Will the springs fit all the perches okay? I figured they would but thought id ask first. Thanks.
00 Black SVT #1545
Ground Control. Koni. 18" Konig Tantrum. More.
The shit has hit the fan. Jared is getting rid of his stock parts! wink
-Colter
My Car
Madic Offline OP
Only these ones, MAYBE do you want me to go to Las Vegas or not?
00 Black SVT #1545
You can bet your ass I do. laugh Just giving you crap. smile
-Colter
My Car
I beleive it does smile I was looking the part number in the comptuer where i work (Pep boys) for the struts and i realize that the struts are the same number through out all years....included The Mercury Mistique(sp) and I believe the cougars too.....
-Mancho- cars name is Connie
99 Silver Frost SVT #1986
k&n filter with cut out box
true duals w/ flows smile
Ground Controls with 17's mille miglia ...
Hightower headlights
15.4 at 90.29 at Milan dragway before the true duals smile
as long as u keep them as a combo, yes..
Paul
'95 Midnight Red SE V6 MTX
mods
Midnight Red Contour Pics
***car under construction***
Madic Offline OP
So the springs will fit anything 98+ and it looks like the struts will work with them all. Intresting.
00 Black SVT #1545
I was under the impression that the SVT springs/struts would not fit the pre 98s. confused
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
If you keep the SVT struts & springs together they can go in any tour. The older tours have a pig-tail bottom end on the front spring, so you cant mix old struts with new springs and visa-versa. I'm finishing up doing new syle struts & springs tonight/tomorrow. (...and balljoints, and wheelbearings, and maybe even an outer CV :rolleyes: )
Scott
Madic Offline OP
twOwheelin, So the top perches are all the same then correct? Thanks for all your help!
00 Black SVT #1545
