Posts: 102 |
I am looking for a way to improve handeling by eliminating body roll with out having to worry about scraping every where !!!!
Any suggestions???
1998.5 CSVT K&N Custom Intake Custom 2 3/4" Magnaflow cat back Ram HD Power Grip Clutch Bosch Platnium +
Alpine deck "CDA-7863" Boston mids
More to come
Stock Sucks!!!!
Posts: 1,444 |
New rear sway bar.....that is your ticket...
Posts: 651 |
Originally posted by Shaun G: New rear sway bar.....that is your ticket... yep...listen to shaun
99 SVT...modified 96 GL....the beater "I live my life a quarter mile at a time. For those 14 to 15 seconds, 16 if I get tire spin, or get a bad jump, or possibly if I have a friend in the car, I'm free."
Posts: 878 |
Stock springs, with bigger rear sway bar and better struts.
"Function before fashion."
'96 Contour SE
Posts: 3,950 |
Front strut tower bar, and a rear sway bar. Should look at the Eibachs. Doesn't really slam your car; lowers it about an inch or so.
Posts: 3,934 |
IMHO, rear sway bar will probably give the best bang for the buck. I have the Aussie Bar on mine and love it! Get backing plates if you get a much bigger bar though. The stock plates will rip off pretty quick if you drive hard. My next mod is subframe connectors.
· Jon Miconi
· 96 Contour Zetec ATX · 80 Ramcharger 360 ATX · 77 Ramcharger 440 ATX
Posts: 102 |
Originally posted by LoCo: Front strut tower bar, and a rear sway bar. Should look at the Eibachs. Doesn't really slam your car; lowers it about an inch or so. Well, I whould love to have Eibach's, But If I go that Route I need new Shock's and a caster/camber Kit and that will cost me over a grand!!! Unless I Wouldn't need the shocks and caster/camber Kit????? However, I know with my budy's honda needed all that $hit just to make his car drivable??? :rolleyes:
More to come
Stock Sucks!!!!
Posts: 7,329 |
Originally posted by LoCo: Front strut tower bar, and a rear sway bar. Should look at the Eibachs. Actually a rear STB will do worlds more then a front will on this car. The front towers are extremely stiff. IMO the major thing up front that should be upgraded is the strut bearings/mounts. I have tell-tale marks of how much they give and move around! Can't argue with the rear bar. Installing the "Aussie" bar was literally Night & Day difference...
Posts: 102 |
Originally posted by DemonSVT: Originally posted by LoCo: [b]Front strut tower bar, and a rear sway bar. Should look at the Eibachs. Actually a rear STB will do worlds more then a front will on this car. The front towers are extremely stiff. IMO the major thing up front that should be upgraded is the strut bearings/mounts. I have tell-tale marks of how much they give and move around!
Can't argue with the rear bar. Installing the "Aussie" bar was literally Night & Day difference...[/b]Whats the cost and where can I get one "Rear strut tower bar"
More to come
Stock Sucks!!!!
Posts: 3,950 |
Originally posted by TommyBoy: Originally posted by LoCo: [b]Front strut tower bar, and a rear sway bar. Should look at the Eibachs. Doesn't really slam your car; lowers it about an inch or so. Well, I whould love to have Eibach's, But If I go that Route I need new Shock's and a caster/camber Kit and that will cost me over a grand!!!
However, I know with my budy's honda needed all that $hit just to make his car drivable??? :rolleyes: [/b]Well you don't really need a caster/camber kit but struts would be recommended.
