#46146 10/19/01 04:14 PM
Roger C Offline OP
Are there signs or symptoms that typically will indicate that the coil pack is not up to par? (V6, '95).
A few times lately there appears to be a longer time than 'normal' for the engine to catch on startup. I'm looking at a second or two.
stock 95 LX,6cyl ATX
#46147 10/19/01 07:51 PM
The coil pack on my car died at 125,XXX miles, it was missing bad! after i replaced it, the car gained most of my gas mileage back and some power.
Paul Brady Ward
JUICE BOX SOFA KING!
Broad Band JUNKY!
F33r Th3 Mirage!
#46148 10/20/01 12:17 AM
Is your tachometer acting funny? That is usually a sign that the coil pack or ingnition module is going bad.
95 Contour SE ATX V6
"Cracked" Secondaries
DMD Installed
SVT Brakes
#46149 10/20/01 03:04 PM
Roger C Offline OP
Tach is OK.
At times I feel I am not getting the response of old when I 'hit the gas', but then there are 193,000 KMs on the car. Last tune up was about 40,000 kms ago, which included wires and plugs.
193000 is not that much really.That's only 115,800 miles.
