Jon - NJNeco
2000 Silver Frost Cougar v6 MTX
Dyno Tested 173.6 whp - 161.2 wtq
Visit MaStaMooN.Com for Details! *Back up in a limited form*
Did you follow my how-to on the Contour.org website??
If so you should NOT have any issues.
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
I posted in your NECO topic.
The first Blown 3 Liter!
"Drive it till the wheels fall off" -my personal motto!!!!
98.5 T-Red SVT #6180
Many Mods
Buckshot77@aol.com
Owner of 00 #1611 Silver
Totalled on 10/7/01
SVT Parts for Sale
No, i didnt find that how-to untill i was already started.. But I have followed the Chiltons Guide, Ford CD (parts), other peoples words, and common sense... None have lead me down the right path though.. I will read over the CEG How-to again.. Cant hurt right?
Jon - NJNeco
Welp, got one done! Had to remove the hub from the lower ball joint.. Only ***** after that was getting the hub back onto the ball joint.. But its a pain that is far less than the past 2 days of trying to install this thing... Only 3 more corners to go!
Jon - NJNeco
Yeah, the balljoint MUST come off the wheel hub or the hub can't drop far enough for the strut to clear. That was definately your problem, the balljoint is definately the hardest part of the whole job. Well, getting the ball joint reattached was anyway. wink
