#394748 05/28/02 03:39 PM
Okay, my brother has a 95 which needs new struts. I recently did struts on my 2000 Grand Prix. Total it took me about 8 hours on my GTP. The rears were a major PIA but I managed to get them ok. So, can anyone tell me if the Contour struts will be similar in installation? If so, I am going to do them myself, otherwise he is going to drop $600 for struts and installation. Thanks for helping.
#394749 05/29/02 02:51 AM
http://www.contour.org/mods/mods.cgi?s=howto&display=springs
heres a how to for you to look at
wheres he getting his struts from???
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
see profile for website, aol name, etc
Business:WestEndMobil@yahoo.com
Personal:Corey_pimp1@yahoo.com
1998.5 SCSVT ($16000 takes it)
2001 GSXR-1000
1988 Corsica (the beater)
#394750 05/29/02 12:30 PM
Unknown as of yet, I was going to see if I could do them, otherwise I think he was going to get violated by the dealer.
#394751 05/29/02 12:48 PM
it will take around ~8 hours to do the job
worth saving the money if you can do it yourself....
if you need are going with some type of aftermarket struts, shoot me an email with what you need
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
2001 GSXR-1000
#394752 05/29/02 01:17 PM
The rear are very easy. The front can be a pain without the right spring compressor tool. If your brother has ever had the front bearings done, everything might not be rusted up too tight. If not, air tools would make the job easier.
If front bearings have not been done, consider doing them while everything is apart. A part shop will be able to press out the old, and press in the new bearing into the knuckle for about $15 each.
If the front is rattling at all, consider replacing the front swaybar end links while you have them off too. $12.50each at http://www.fordpartsonline.com/
96 2.5L SE manual
99 4.6L F150 XLT 4x4
#394753 05/29/02 02:09 PM
I have a friend that owns a shop, I can use their McPherson Strut compressor no charge. I don't mind doing bushings, but I know nothing about bearings.
