Originally posted by Lee:
From looking at them I think they are cone shaped and will only bolt into the Hub one way.
yes they are cone shapped. The reason is so that as you torque the nut down the tapered pin on the tie rod seats into the housing making a tight fit.
Milling the hole to a straight bore will make for a loose fit. This will only result in problems.
