You could get a set of Roush springs for the v6 cougar for $120 shipped. They should be a direct swap for your springs, maybe a little on the sporty side, with about an inch drop. Pretty cheap compared to eibachs or the H&Rs. You will have to switch to the 98+ front struts to use those springs with a 95-97, but that is an easy thing to do if you are gonna replace the struts/springs as a set.
http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=46;t=000460
