#394512 05/11/02 07:03 PM
goatis Offline OP
Is there some secret to removing the old sway bar/installing new one without messing with the gas tank? theres no way in hell the bar can fit through that little space.. I don't want to mess with the gas tank.. boom!
thanks
metallic teal 95 mystique V6 ATX
debadged-no door dings-K&N filter-no hoodliner-SVT exhaust (thanks steve!)- Powdercoated Black E1s -SE side skirts in the garage! LED stereo and door handle lights
No need,I never move or drop the gas tanks to remove or fit a bar.......
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
H
H
The gas tank is held in by two straps with 13 or 15mm bolts. Just place a jack under the tank and lower it down maybe two inches. The bar would not clear the tank withour this adjustment in my installation.
98 T-Red Contour LX V6 Mtx 106k miles
9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
what they say, no need to mess, just loosen it a little wink
--alex | 96 GL(sort of) V6 ATX | 98 SE V6 MTX Sport
Its plastic,fit the bar with a 1/4 or less of a tank... :rolleyes:
V6 MTX
FWIW, I did not remove or lower mine at all. After spending an hour trying to finagle the bar out, i finally just pulled like a mofo. The gas tank was nice enough to flex just enough for the old bar to pop out the passenger side and the new one to slide in from the passenger side.
Not saying I reccomend this approach, just that it worked for me....... :rolleyes:
98 SE
BAT Big Brake Kit "C", Throttle Hang Fix, B&M Shifter, Lightly Cracked Secondaries, BAT Euro Handling Kit, 20% tint, Removed Ding Strips, ES Motor Mount Inserts, Borla CatBack, Apexi SAFC, HighTower Rear Brace, BAT 19mm rear bar, MSDS Headers & Y, AFE 20-35008 filter, ClutchMasters Stage 1, Fidanza FlyWheel, SVT T.B.
====OnOrder====
svt uppers and lowers,
I did what Bruce did to get my 21mm bar in - just kept pushing and pushing, and finally that bar went up into its new home.
-Kurt
-Kurt
"I'm a little sceptical of that internet thing. After all, what's it got besides information?"
-DB, 1/97
One word - CROWBAR!!! Hooked on leverage worked for me!
Scott
96 SE, MTX, BAT 22mm rear anti-sway bar, BAT springs and Spax struts
96 Caprice, 9C1
Rayon is made of wood!!!
I don't think you even need a crow bar...unless it varies from car to car....Just jack/ramp the car up and and position the bar properly...then grab a hold of each side and SHOVE THE HELL OUT OF IT!!!
Really it didn't need much force at all!
wink
Worked for me!
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
A how to with pics would be good for this mod. Anyone interested could come to my house and do it on mine laugh
"Wow, that sank fast." "Yeah, like a rock."
96 Contour GL ATX
9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned
Sony CD player: 50wattsx4;remote;
Speakers=50 watt Pioneer 6x8s
Ross Evans smile
