Originally posted by RubberDuckySVT:
Point of the story: you will get bad kharma if you try to install that stuff yourself.
Well that is going to suck. I am doing a bolt pattern swap on my `77. Have to change the rear axle shafts, front spindles, outter front axles, brakes all the way around, and caliper mounts.
Well at least I won't be driving behind myself if something happens.
Was the result of the crash because of driver error or mechanical failure?
