Posts: 39 |
Are the coilovers supposed to look like they'll fit a tricycle? They finally came in today and they seem really small. I'm not sure if that's how they're supposed to be or not or if I'm supposed to buy other parts to mount it. Will it work with stock struts?
96 Contour LX V6 red ext. with tan leather int. All options except ABS(who needs brakes anyway) Bosh+4 plugs and 9mm Ford Racing wires OBX racing intake Aerospeed DTM style muffler with 2.25 custom catback piping - no res BAT struts Ground Control Coilovers OMP strut bar
Posts: 482 |
The coils themselves should be 2.25 in diameter. The springs dont need to be THAT long since they fit over the adjustable sleeve. A bigger spring will dimish the "adjustability"
Jonathan 98 SVT E0 #4290
Posts: 3,223 |
You are going to waste a lot of time or money putting GC's on stock struts that will fail rather quickly! They may not look like much but they do a lot!
-Andy
Posts: 39 |
Thanks, they are 2.5 in diameter. I read elsewhere on the site that they work best on stock struts though as well as another brand (I think Koni). What kind of struts do you recommend. Thanks alot for you help by the way
Posts: 217 |
Koni struts is the way to go
Posts: 3,223 |
Lets beat a dead horse one more time!
After market suspension spring have a very high rebound rate. Stock struts are not made to handle such high rebound rates and will fail rather Quickly. GC's have these higher rebound springs.
The only other struts out there that are made for higher spring rates are Koni's and BAT Inc. struts which are rumored to be Bilstein's.
-Andy
Posts: 39 |
Thanks alot for the advice. I'm currently in the process of ordering BAT Euro Sport Struts for CTA Motorsports in Canada. They currently have them advertised for $95 each but that price will be finalized on Monday. Is this the cheapest price or do you guys know places where I can get them cheaper. I'm not going to buy the Koni's because I'm sacrificing to buy these struts as it is. Once again thanks for all your help.
Posts: 1,444 |
cheap kybs u can reach corey, the resident suspension seller. his kybs are cheaper than the bats. dont know which is better, just giving u some options.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 3,223 |
I was told the KYB's are factory replacements not made for higher rebound springs!
-Andy
Posts: 1,795 |
Originally posted by Andy W.: I was told the KYB's are factory replacements not made for higher rebound springs!
-Andy I heard that, as well as the opposite, hence my GC's still have no struts, well that and I ampoor too :rolleyes:
Every time I come online I wonder if the forums will be up
