I've seen much discussion about these "upgraded" end links. Well just recently i did a ground control install on a 2001 cougar.
First off the nut you need to hold with a wrench to remove the end link from the strut is 15mm and not 17mm like mine was on my 2000 cougar. Next looking at the end link it looks MUCH strong then mine do, and the end bushings were integrated into the bar. Anyhow a quick search for this part says they are less than 20$ each from your local dealer, not sure if anyone wants to investigate this but it may be worth a shot.
2000 Cougar V6 MTX
Black
Visteon GFX Kit with Razzi rear skirts, Ground Controls, YoDude Exhaust, Ractive Filter, Custom Interior, Custom Loud Stereo, and more...
See Her Here
