Posts: 149 |
How are you guys with Koni adjustable shocks getting to the top of the rear shocks to adjust them easily? Would it just be easier to get GAB shocks with the side adjuster?
JasonS 2000 Silver Frost SVT #1119 of 2150 Eibach Springs / Corbeau Forza II Seat / TRW Sabelt 5-point belts / Pegasus Brake Ducts / Braided Steel Brake Lines/KVR pads / Black SVT Rims / Mirko Racing Front Airdam / Clear Corners / Knauberized Best Lap Road Atlanta: 1:56.1 -stock KDW tires!!
Posts: 1,036 |
Just need to modify one of the adjusters by cutting off some of the plastic lip that your fingers touch while turning. This will give you more depth to turn.
98 E0 Silver SVT KKM - Bassani - MSDS - BAT - ES - Unorthodox - HID - Dyna-batt - Koni - Ground Control - 17" MAS Italy Rodger - Quaife - Fidanza
"Every easy girl I have been with has been either a hosebeast or a headcase" - Pete D
Posts: 76 |
I can use the adjuster on the one behind the drivers side, the other side you have to rig something up, the knobs too big, I just pulled the plastic piece out of the middle and used a pair of pliers to turn it
1999 Black SVT/5% Tint/Bassani/Konis/Eibachs
1965 Ford Mustang Fastback/In Progress
Posts: 2,915 |
thats odd
i can adjust mine fine with the knob they gave me, even for the rear :p
www.shox.com Dealer Koni's 135 a piece Eibach's 190 a set KYB's 70 a piece H+R's 225 a set see profile for website, aol name, etc Business:WestEndMobil@yahoo.com Personal:Corey_pimp1@yahoo.com 1998.5 SCSVT ($16000 takes it) 2001 GSXR-1000 1988 Corsica (the beater)
Posts: 117 |
I took the middle out of the Koni supplied knob and glued it into a socket, can't remember the size, and use a small ratchet. Works really slick.
99 Black&Tan SVT #308 - For sale Borla Catback, K&N Blaupunkt '01 Audi S4 Avant yeeehaa!! 91 Audi Coupe Quattro- For sale 68 Mustang Convertible (summer fun)
Posts: 2,657 |
Originally posted by Corey: i can adjust mine fine with the knob they gave me, even for the rear :p Same here. I smell user error... :p
Posts: 125 |
For the rear struts, I had to shave mine adjuster knob down a bit, but then it fit right on. I don't know how you could reach it without any mod.
98.5 SVT, Vortech SC, Bassani, Quaiffe, Clutchmasters Stg. 3, BAT Sport Springs/Konis, 17" Momo Arrows, Sparco Brace,BAT 22mm Sway Bar, PIAA fogs & headlights.
Posts: 43 |
Mine works without any mods. Just stiffened them last week. Winter's over!
Dave T. '98.5 Silver Frost E1 #4596 of 6535 Koni's Fog Light Mod Motor Mount insert
Posts: 1,041 |
The shop that installed them told me I would have some problems adjusting the rears. But i got home to check it out, no problems at all. Not sure if was refering to past experiences or what. I have no problems though. I would pull the back seat down to take a closer look if your having problems.
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
Posts: 76 |
thats weird, on one of my back ones theres no way to fit the whole width of the knob, the metal structure under the back shelf is in the way, even if the seats were down.
