I
I
Hey folks,
I just got ground controls and koni's installed on my SVT, and now the rear end clunks badly when it goes over bumps. My mechanic says it's because there are no isolators like in the stock suspension, and this is not uncommon in setups they've seen on mustangs, but I wanted to check on this. Can others confirm if they got clunking after installing this stuff? I have no sway bars or tower braces, only the new shocks/coilovers. Anyone got an idea what's going on here?
--Ross
GCs & Konis for 6 months+. No clunking.
Don't know what the clunking is... confused
- Pete - 00 SVT SF/MB - 1522/2150 - DOB 1/12/00
92% says your group-NOT HOT
85% says your either wrong or BLIND
Blackhawk Down did NOT suck
you know who you are.....
I
I
Originally posted by ikarius_svt:
Hey folks,
--Ross
Check your brackets thats holding your sway bar.
99 Range Rover 4.6 HSE
Mystery Car??????
The biggest error made when fitting after market/ lowered suspension is that the existing suspension bushes/links are not unbolted to let bushes sit in the 'neutral' position with the lower set up.This places added torsional & radial loads on the stock bushes and can rip them out.The worse part for this is the rear stab bar links,the small upper rubber bush is weak to start with.None of the bush thru bolts should be tightened until the the full weight of the vehicle is on the suspension............ wink
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
I
I
BTW, this is not clunking when I'm accelerating laterally, this is when I go over bumps, and some of the clunks are pretty horrific. I'll be taking the car back to my mechanic this morning, hopefully he'll figure out what is wrong.
--Ross
Laterally confused what kind of drivetrain do you have :p I want one!
T-Red SVT E0 #2321 of 6535
I
I
Dude, lateral acceleration is cornering man :p I just thought that was when people got clunking from the sway bar brackets and stuff.
--Ross
Sorry, lame humor attempt frown
Can you reproduce it by just bouncing the rear suspension manually? Maybe you could better localize it that way.
I
I
Nope, I can't do that. The clunks are generally when the rear suspension drops quickly. Fast bumps, or drops in surface level and suchlike.
--Ross
Id check what terry said to check. it very well could be your sway bar bushings.
'95 Tour LX
ZETEC MTX
TOO MANY MODS TO LIST ANYMORE!!
http://www.geocities.com/marine113
Best mod ever to my tour: A Beautiful passenger seat filler, that is my Beautiful Girl!!
