Posts: 64 |
OK, I'm feeling stupid!
I bought the SHO Shop Subframe connectors.....now where the heck do I weld them??
Anyone got some clear pictures or a good description?
I guess, (having dealt with SHO shop before), I should've know there would be no instructions, descriptions, or anything else included!!
Thanks ahead of time!!!
99 SVT (Black) # 2642 of 2760 Mirko Racing Intake \K&N Filter (RU 3130) BAT Air Inlet Pipe HD Motor Mount Inserts \Front - Rear Sway Bar Bushings BAT 22mm (Rear) Sway Bar, Bat Springs \ Koni Sport Struts Performance Fords - Spherical Rod End Links (Rear) Performance Fords - Street Link SHO Shop Strut Tower Braces (Front and Back) SHO Shop Body Sub Frame Connectors Aeroquip Stainless Steel Brake lines (Front/Back) Sho Shop "Y' Pipe Magnecor Wires \ Bosch +4 plugs Ford Dual Mass Crank Damper Pillar Guage Pod Perma-Cool Remote Oil filter Mount Summit Racing Polished Almn Battery Relocation Kit MSDS Headers (not installed) B&M Short Shifter Sparco Pedals (4 pedal set) (I think I got 'em all)...someone sell me something else!!
Posts: 1,225 |
I'll be taking pictures of my subframe connectors this weekend. Keep your eyes peeled, pics will be up on Monday!
Ryan
Latest Mod: Mirko Splitter
Posts: 64 |
Posts: 45 |
Mine are welded on front section with two inch welds spaced two inces apart. In the rear, the box section is welded in all the way around. Sorry, ,no pics.
Posts: 45 |
Make sure to weld in on a "drive on" lift, as to not pre-load the chassis!!!!!!
Posts: 650 |
A "drive on" lift is a lift with the two big rails so that all four tires are seated as if it were on the ground right?
Ohsigmachi '96 GL MTX Zetec SS (SuperSleeper) Suffice it to say my mod list has become so long that it is just ridiculous
Posts: 1,225 |
Originally posted by OhSigmaChi: A "drive on" lift is a lift with the two big rails so that all four tires are seated as if it were on the ground right? exactly, keeps the suspension in it's normal position and doesn't allow the SF connectors to preload the suspension like was mentioned before.
Ryan
Posts: 64 |
Thanks for the tips!!!
Does anyone have any pictures yet?
Mikey
Posts: 108 |
Anybody? Anybody? Bueler?
Posts: 1,225 |
I totally forgot about posting pics, sorry guys! Well here they are, I know they're not the greatest pics but mind you my car was only a couple feet off the ground so I took the pics on my back. Tip for the day: make sure you paint the connectors! Yes they are stainless steel but surface rust will still form and it looks horrible. I spent an hour with an angle grinder cleaning all of the rust off so I could paint the connectors. If something doesn't make sense with the pics just ask, I'll see if I can clarify.
Ryan
