Posts: 1,447 |
After searching and searching I found.....nothing. So what can we do? I have roasted the inner parts of both front tires in just 12,000 miles (belts were coming out  ) I just bought new tires and dont want the same result in another 12,000 miles. I could not live without my H&R's, they add such a great look, any ideas??
Posts: 1,181 |
That sucks, only 12k? What were your camber specs? Were you rotating them often?
My camber with H&Rs is about -1.0 to -1.3. Is that enough to cause much premature wear?
98 Merc. Mystique LS
Red Wings and US Soccer 0wn j00!
Posts: 1,447 |
Dont have the spec they are at after the drop. I started off rotating the tires every 3000 miles when I was at 12,000 (when I got the rims/tires new). The front tires that were just replaced had been on the front for 6,000 miles straight (been to the drag strip a few times in that strech too). I'm not worried bout the wear, its the uneven wear I am concerned with. two thirds of tire still had good tread.
Posts: 168 |
can someone tell me what camber is??? TIA
'98 S\/T K.I.A 6/14/02
Posts: 1,447 |
I dont have a exact definition but, I would call it the pitch (angle) the tire sits on a horizontal plane (the ground). too much one way and the inners wear prematurely, too much the other has the opposite effect.
Maybe someone can refine my statement
Posts: 146 |
Well, I'm pretty sure this is right, but sorry if I'm mistaken... it's when the tires are sit like this
Get it? Angled so the inner or out part of the tire wears quicker than the other part. Hope that helps some.
1998 black Contour SVT E0 -KKM Intake -Magnecor 8.5 mm spark plug wires -Bosch +4 platinum spark plugs -B&M Short Shifter -SPARCO front strut tower bar -17x7 Rage 5.0's with Nitto NT450's (215/45-17) -24mm Aussie rear sway bar
Posts: 1,507 |
Originally posted by YoungGun:
nice use of slashes
-- Mike (Moe)Lester -- 98.5 SVT #5486 moesvt@comcast.netGet your a$$ on IM and stop wasting bandwidth!!!!!!
Posts: 376 |
Quick definition would be the inward or outward tilt of the tires at the top. negative camber the wheels are tilted in at the top, positive is just the opposite.
~Shawn Clone~
1999 SE Sport V6 MTX Silver frost/Midnight Blue BAT Euro Handling kit, SCA Cold Air intake, painted dash/calipers, Elky's mesh grille, bulitt fuel door,B&M shifter, ES motor mount inserts, OMP front strut tower brace, newest mod- HPP rear strut tower brace ...coming soon, Aussie Bar Possabilities in the works: Custom CAI, Polished stainless shifter cover plate
Posts: 1,447 |
Excellent, I was trying to show a pic that would describe it, the dashes are exactly how my tires wore  Looks as if someone took an Xacto knife to my inner sidewalls
Posts: 108 |
Dude get your checked, I put 35,00km on my ZR rated tires and after I lowered my ride and the inner part of the tire never wore...The only reason my front tires are getting low are becasue I decided to do a burnout with my car and I toasted them ($450 gone) but it the memory and the video I have of it is PRICELESS... And I also drive my car hard and don't ahve a camber kit.
98 Mystique GS Silver Frost Pearl V-Racing Aluminum Touring Wing SVT Front Bumper with some added touchs SVT Side Skirts Eibach Sportline Springs 17x7.5 BSA 187 wheels with 215/40ZR/17 Mondeo Badge APC Sidemarkers (Light up Red) Hiper Industries 100W H.I.D. Bulbs (Highs, Lows and Fogs) Blue Reverse Lights Red Turn Signals All Around 2 Red Tenzo R Adjustable Bucket Seats Shaved back door handles (thats right only the back) **And a few other mods** Coming Soon Custom rear bumper, and a sound system
