#393379 03/05/02 09:05 PM
I've had my E1 for almost 4 years and for the past several months the Detroit roads have been driving me crazy (more than usual, that is). Over most bumps (not just the severe ones) I feel a lot of wiggle at the rear end. I've had my front and rear alignment checked twice and it's fine. Any suggestion as to what might be causing this?
#393380 03/06/02 03:51 AM
Is it colder than normal?
#393381 03/06/02 04:16 PM
Yeah, it's cold here but it feels like a bent control arm or something. It doesn't feel wiggly one day when it's 20 degrees out and perfectly fine the next day when it's 55.
#393382 03/15/02 10:00 PM
E
E
my control arm just got bent, and my '97 is doing exactly what yours is. go over the smallest bump and it feels like my a$$ end is gliding all over the place.
as for the weather it has been a lot milder than most winters here in chicago.
check for a bent arm. and speaking of bent control arms... anyone have a good, cheap source for replacements?
'97 Contour LX
2.5L V6 PFI 24V DOHC
no mods as of yet, but they're coming.
#393383 03/16/02 03:02 PM
6
6
My a$$ end get's all wiggly over certain roads and conditions, but it turned out to be a broken sway bar bracket. Right rear, not the D clamp, but the actual weld in bracket.
You might want to see if D clamp didn't slide out of the tab. I was at Ford the other day discussing my situation, and one of the techs said he's seen it a few time's where the D clamp has popped out of the tab insert. BTW, the D clamp is the bracket that goes over the bushing.
My two shiny pennies worth,
Mike
I have a dream, and that is a 69 Boss 302 with Jules Asner in it.
Current - 2002 Chevy Silverado
Former - 98 SVT E0 T-Red 4/4/97 #173 of 6535(so long girl, you'll be missed)
#393384 03/16/02 11:16 PM
E
E
The toe arm was bent on my `96 for awhile. When the suspension would move the car would gain rear steering (with one tire!). Quite a strange feeling indeed.
The shop that was working on my car bought the part from Ford. fordpartsonline.com or Bill Jenkins would be a good source.
smile
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
