2
28E Offline OP
2
Has anyone tried just adding the rear strut tower bar instead of going all out on the other suspension mods? Thanks
I
I
This would be the best way to start Suspension work if your on a tight budget..
1st rear sway bar 19mm-24mm pick what you want
2nd Rear Strut tower brace- sho shop
3rd front strut tower brace- www.Ompwins.com
Ohh and yes you will notice a differnce with just the rear bar.
Yes, you can start with just a rear strut tower brace, and yes, you will feel a pretty big difference with this mod. You can buy them from SHO shop, or you can do what I did: Take an old front strut tower brace and mod to fit and it only cost me 20$. Here's a pic:
[img]http://www.fototime.com/ftweb/bin/ft.dll/standard?pictid={428674D4-C983-48AA-A478-D7D1EE8E23FD}[/img]
All I had to do was built some mounting brackets and weld them to the strut towers, bolt in the bar afterwards and pre-load it. I liked this particular bar because it allows for more clearance through the seats.
-Jeff
-"The Crazy Canuck!!"
-"Rice": Anything that looks faster than it really is...
My Ride! http://members.sounddomain.com/sideoftheroad
