Shaun G Offline OP
Anyone got the Rear Tubular Adjustable Control Arms from SHO-Shop? If you do, what do you think?
I askes this about 3 weeks ago and there was no reply. so you could be the first. I want to get them and have the same questions you have. have you seen the front arm of the rear that holds the sway bar that Performance Fords makes. It looks good but you have to drop the rear sub frame and I do not want to do that unless it is easy.
98 SVT Black
#3502
BEL_SVT@home.com
Shaun G Offline OP
Me..first? How about you first...
Seriously though, the Ford Performence tubular rear control arms are just stock arm with a plate welded to them to close the U opening. I was hoping for some real tubular control arms.
Something like these
these are for a mustang
I think you should call SHO-Shop and ask them...
lol..ok?
I have. The perosn said that it can be put on by the home shop guy meaning you do not have to have a lift. he said he has them on his SHO and it helped out a lot. but they do need to be aligned by a pro. I think they would nice to put in. I have the sway bar in gradge that needs to be put on so since I am going under the car I was looking into them. The sway bar ones are the ones that I want to put in first, but I do not know how hard it is to put in. also that one has the swaybar link on it so that is way it is a box.
98 SVT Black
#3502
BEL_SVT@home.com
Shaun G Offline OP
I'm not so worried about putting them on just what kinda of quality I'm getting. Front tubular arms would be nice also. Did the SHO-Shop say they were "real" tubular arms or welded old ones?
They are real tubes with an adjustment for camber or caster not sure and they are powder coated.
98 SVT Black
#3502
BEL_SVT@home.com
Shaun G Offline OP
hmmm...I may get them then...
F
F
I actually just ordered a set 2 hours ago, I'll let you kow if there are any problems...
1995 Contour SE
V6 5 spd
My life is a lot like cold women and warm beer.
