jng Offline OP
Hi,
I saw posts about problems w/ upgrading to larger sway bars.
My lx has ~80k miles and my mechanic says that the rear sway bar links need replacement. My question is, if I upgrade to a 19mm bar, will I have any problems (e.g. new links will wear out sooner, etc.)? Thanks.
Nope, Get new links bacuase you need them anyway. Buy the Aussie Bar from Terry.. Check the Forums.
Its a great mod at a great price!
Joe
1998.5 T-RED SVT
18" Team Loco 142's W/ Dunlop Rubber
181.2hp@6900rpm/155tq@5000rpm
LOTS OF MODS OF EVERY KIND....
...Am I a guru yet??? No... not yet.
jng Offline OP
Thanks for the response. I think I'll go w/ the 19mm bar. I don't want to change the characteristics too much.
F
F
A cheaper option may be going to a early SE 19mm bar someone may have laying around or an SVT 18mm, bar people have lying around. Lots of people bought the SCA, BAT, or THM bar. So finding someone shouldn't be too hard if you want to go that route.
Better measure first, as I believe your car came with the 18mm stock. Quite honestly, the 19mm is your best bet unless you want the additional headaches of squeaking, rattles or weld on reinforcement plates at the bracket mounting point. And then the brackets are prone to bending, breakage too. Anything other than a 19mm is not a straight bolt-on mod.
Technical Director/Co-Owner Performance Fords-check out our new throttle body service
95 SE with lots of custom 1 off mods. All design, fabrication and installation by owner.
jng Offline OP
Guess I'll measure it first. I thought early non-SE contours had 16mm rear bars. Thanks.
95-97 SE had 19mm rear
SVT's had 18mm rear
All others had 16mm rear
2000 SVT #674 - Check it out!
Depends on high well you want to corner and what you're prepared to do for it. goin from 18mm to 19mm wil only get you a 24% improvement in body roll and cornering ability.
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
But he would be coming from a 16mm. Then a 19mm would be substancial stiffer.
It'll still plough like a b@stard!
Regards,
Anastazi
