Page 2 of 2 1 2
Originally posted by PA 3L SVT:
I thought a lot of that was 95 MY only, with the different injectors, etc. than the SVT.
It's the same intake setup as all the Duratec's. The only difference is the SVT has the extrude honing inside the intake. Same injectors, same manifolds.
'96 Contour SE, black / opal grey, MTX, every option, KKM intake, resonator removed, Flowmaster Series 40 DeltaFlow, GoodYear Eagle HP's, 115k miles, new paint 7/01. Driven cross-country 4 times.
'70 Corvette Stingray Coupe, Cortez Silver, 454 bored to 462, Muncie M21, too many mods to list, lots of fun. 335 rwhp / 365 rwtq
'02 Corvette Z06, Electron Blue / Black, every option. Stock for now...
It very well could be the gaskets. I swapped my upper intake with an SVT one and disturbed the aged gaskets after reinstalling. Had to pay a ton of money to have new upper and lower gaskets put on. I proabably could have done them myself but I just let them go ahead. I don't know why they would be leaking on your car if no one has tried to remove the upper intake and your car is fairly new compared to mine. Oh and please don't give quotes on a 75 hp gain from the air conditioner mod buddy or people will ignore you. You don't even get that much power from a Vortech supercharger on these cars.
"If you're pushing crazy I'm all full up here."
{Black '96 Contour SE MTX w/ over 126k on the clock}
· Get the skinny here.
· Need a 96-00 Ford Service Manual on CDROM?
I'm sure he was kidding about the 75 hp gain. C'mon, what's that a 40% increase? :rolleyes:
You may not have a problem with your intake manifold gaskets. I had a the same diagnosis and it ended up being a small crack in one of the vacuume hoses. I would check them before you shell out the $$$ for new gaskets.
99 CSVT Green/Tan 13,700Km
# 84 of 2760
For Sale
96 Contour GL 2.5 ATX 120,000Km
K&N Air Filter
Mobile 1
E1 SVT Wheels & BFG G-Force Rubber
Aluminum Painted Front Grill
Q
qaz Offline
Q
I saw a sign at my local Autozone which says something to the effect of "Check engine light on? We have a scanner and can tell you why!"
Brian
I don't know why people are replying to this message now when the problem occurred last year - but I appreciate it anyway.
I had the Ford dealer reset the check engine light and it never came on again. I kinda knew that they were full of crap because if my intake manifold gaskets were leaking, I would have noticed something besides a light on the dash.
Thanks - Dave
Sorry for the late post. You never posted saying that it was fixed. BTW to reset the CEL you only need to disconnect the battery neg cable for about 10 min and then reconnect. I hope they didn't charge you for that.
# 84 of 2760
For Sale
K&N Air Filter
Mobile 1
F
F
an easy way to check if the intake is leaking is to take a can of cab cleaner and sprsy around the intake runners and see if the idle gets irratic. this thing has got to have a fairly big leak if the check engine light is on and the carb cleaner should be able to pick it up
Page 2 of 2 1 2
