Posts: 117 |
I know this probably sounds stupid, but how did you all adjust your rear shocks??? I see where it is but its hard for me to see to stick the knob on to adjust it and to be able to know how much I adjusted it!!! I'm I that retarded??
98 SVT switchin 4 lanes windows down system pumpin screamin out money aint a thang!!!
Posts: 2,915 |
Originally posted by L-Train: I know this probably sounds stupid, but how did you all adjust your rear shocks??? I see where it is but its hard for me to see to stick the knob on to adjust it and to be able to know how much I adjusted it!!! I'm I that retarded?? mine stuck up far enough to reach with the knob, what i did with mine, was turn them either all the way hard or soft, then put a mark on the knob, and how ever much i turned the knob, i did for both, i think i turned mine one full turn hope this helps
www.shox.com Dealer Koni's 135 a piece Eibach's 190 a set KYB's 70 a piece H+R's 225 a set see profile for website, aol name, etc Business:WestEndMobil@yahoo.com Personal:Corey_pimp1@yahoo.com 1998.5 SCSVT ($16000 takes it) 2001 GSXR-1000 1988 Corsica (the beater)
Posts: 115 |
I received two adjustment knobs with the set. One knob I left as is, the other I wittled away the outer plastic.(damn I wish I had a photo to show!). The knob as it comes from Koni does not fit in the space of the rear strut tower. By wittling away the edges around the knob (from the bottom side, not the side that has the writing on it), the knob sits in the space at the top of the strut tower better. This will allow you to seat the knob in there and find where it will latch into the strut. I hope this helps. If you need more info email me at svtcontour@rogers.com. Cheers!
1999 SVT Contour Silver Frost Bassani, Konis & Eibachs "Low & Loud!!" 17x7 Rage 5.0 / Nitto NT555 225/40/ZR17 / Aluminum Look Dash Kit / Some Serious Bass From 2 12's
Posts: 2,915 |
mine fits fine.... the strut is up enought to reach the knob
Posts: 1,090 |
Originally posted by SVTFern: I received two adjustment knobs with the set. One knob I left as is, the other I wittled away the outer plastic.(damn I wish I had a photo to show!). The knob as it comes from Koni does not fit in the space of the rear strut tower. By wittling away the edges around the knob (from the bottom side, not the side that has the writing on it), the knob sits in the space at the top of the strut tower better. This will allow you to seat the knob in there and find where it will latch into the strut. I hope this helps. If you need more info email me at svtcontour@rogers.com.
Cheers! This might be a little easier. I took the short ones, pulled out the middle piece, bought some plastic super glue, it has a type of "kicker" or something like that, but you brush the kicker on first, then apply the super glue. Anyways, I looked how the two pieces are joined, it only can fit one way in. I cleaned both pieces (handle and slotted plastic piece), brushed on the first liquid, then put on small drops on the areas of contact. I then pushed the two pieces together, but did not push them all the way, letting the slotted piece hang out about a 1/4 of an inch or so (just eyeball it). Permanently bonded, and easier to get the adjuster on! Then mark the knob like the others said.
Posts: 2,156 |
I also had to wittle away the outer plastic. mine doesnt come up far enough, but if you take out that out plastic for it to go in the whole it should reach. at leats mine barely does.
Sam 1998 Contour SVT #180 1/4=14.2 @ 101.17MPH
AOL users = PhatSVT _ _ _____________ _ _
1986 Mustang GT 12 second club
Posts: 2,657 |
I got two of the same knobs and they both work fine on the struts. The rears are a little harder work with but it reaches them fine.
