The specs don't change. The readings will. You will have more negative camber. It may still be in spec. You can also have tire wear as you have described from excessive toe out. I happened to me. It seems that the toe out on the fronts grows over time so i recommend setting the front toe as close to 0 as possible while still just barely being toed out. Set the rears as close to 0 as possible while still being just barely toed in.
There is an excellent discussion about the camber change from installing lowering springs in the BAT catalog.
www.batinc.net I wish that someone made an aftermarket camber / caster adjusting system for our cars. There are companies that say they have them in the works, but do not actually have them for sale yet. I would feel more comfortable with a little less negative camber in my car.
