#392285 12/20/01 07:57 PM
H
H
Ok right now my car is on the jack with the wheel off. Weve undone all the bolts but we cant break this ball joint kinda under the rotor. Does that need to come off? On the thing on this website that says how to lower a contour it says do not take out the strut. Well how can you get the spring out?? UUGhh this is hard!! lol
98 Contour
Baby Blue
Eibach Springs
17' White Motegi MR12s
Sumitomo 205/40 tires
Mesh Grille
White Brake calipers
Pink Valve Cover
Removed Door Dings
2 Punch 12's
Jensen Amp
Side Marker Lights
Billet Antenna
White Girlie Girl Racing Sticker
Coming Soon..
Svt Body Kit
Dual Exhaust
Baby Blue Tint
Air Cylinders
http://gurlpages.com/girliegirltour/main.html
#392286 12/20/01 08:02 PM
OK, hopefully the strut is still bolted into the tower, right?
OK, now get a wedge or cold chisel and tap it into the split in the knuckle where the ball joint is held (After you have removed the bolt COMPLETELY from the hole). This should spread the knuckle and loosen it. Then step down on the A-arm and swing the strut and knuckle to the side.
PS if you need help call me at work right now 1-800-299-AXLE and ask the receptionist for Stazi.
PS I wrote those instructions so I know what I am talking about. wink
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
#392287 12/20/01 08:17 PM
H
H
ok thanks sooooo much i understand now. Are you gonna be at work a while longer in case we get confues about anything else
98 Contour
Baby Blue
Eibach Springs
Mesh Grille
Pink Valve Cover
Removed Door Dings
2 Punch 12's
Jensen Amp
Side Marker Lights
Billet Antenna
Coming Soon..
Svt Body Kit
Dual Exhaust
Baby Blue Tint
Air Cylinders
#392288 12/20/01 08:19 PM
For another 2 hours
PS make sure you DON't pull on the shaft as it will separate from the inner CV joint and then your in the shiz!
What you should do it is get a couple of BIG zip ties to loop around the back of the inner CV joint and then around the front, connecting them together tight to hold the joint together.
Regards,
Anastazi
