Posts: 9 |
wat combination of spring/strut is the best for street application( also along with strut/sway bars )
~svt racing~
Posts: 9 |
and to also add, compatible with the braking system( we all know a good braking system isnt good w/out a good suspension ) wat im trying to say is that i dont wanna stop on the dime, i wanna stop on the nickel!!!
~svt racing~
Posts: 2,906 |
Strut choice is usually the Koni adjustable struts. Springs are just a matter of choice as they are all pretty much the same performance wise.
As far as brakes goes, if you want to stop on a nickel :rolleyes: Your gonna have to get a big brake kit which is not cheap. This kit will pretty much snap your neck when you hit the brakes.
Sway bars...there are some: a 21mm bar from SCA and a 22m bar from BAT. Also I think the AAM Hollow 24mm bar is being sold again and in my opinion better than the other two.
Josh Aka Spectra SVT 02 Dark Highland Green F-150 XLT Mods: Gunrack and cowboy boots
Posts: 3,934 |
A set of stickier tires will also help the cornering and stopping. You can have the best brakes, and awesome cornering power, but if you are running on a set of tires that is meant to last forever, you will still give the ABS a workout and be able to break the car free is you corner too hard.
· Jon Miconi
· 96 Contour Zetec ATX · 80 Ramcharger 360 ATX · 77 Ramcharger 440 ATX
Posts: 3,567 |
thats right the battle of keeping the car on the road will always come down to where the rubber meets the road.
Choose your tires wisely.
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
