#391933 11/27/01 10:49 PM
I'm thinking this is some kind of a mount issue, but I supose it could be clutch also, so I'm looking for more input.
I'm having trouble getting into gear when parked, sometimes when the car is level, ALWAYS when the passenger side is lower(i.e.roads with a high crown), and never when the driver side is lower.
This isn't where I just have to push it into gear either. This is where I have to sometimes jam the shifter to get it to go, and once it goes there's usually a clunk felt inside the car also.
Any help or idea's on what this may be, I'm pretty lost
'99 Silver Frost SVT
all stock for NOW
Bleed the clutch first...
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
where is the bleeder valve ??? engine bay or down on the slave cylinder ?
all stock for NOW
Left of the battery tray,go down to the bellhousing,black rubber cover with hyd tube to rel bearing/slave(in trans).Bleed nipple too front of hyd tube connection.M8 I think
V6 MTX
cool, I'll give it a run as soon as this nasty ass freezing rain stops
all stock for NOW
