#45693 10/03/01 11:04 PM
I have a grinding sound coming from my engine bay. I believe I have actually narrowed it down to the idler pulley. It almost sounds as if the bearings have gone bad.
Its tied to rpms, if the rpms go up the sound increases in frequency as well.
My question is: Is this common? and if I replace the Idler pulley does it come with the bearings? Could it be something attached to the idler pulley. All I really know is thats where the sound is coming from.
Thanks,
Justin
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
#45694 10/03/01 11:59 PM
Are you talking about the idler pulley or the tensioner pulley? I also have a grinding noise from my idler pully. I bought the pulley, it cost $25 i think, and it does come with bearings already installed. I however haven't installed it yet cause i don't have the time or any wrenches, cause you can't fit a socket wrench to it. Hope i answered your questions.
95 SE MTX
Throttle Hang Fix
Fogs come one with Parking lights
Custom exhaust(no res)
17" White Axis Touring Cup
Perili P7000 Supersports
KKM Sport Induction
Windows tinted 15%
EIBACH Springs
Superchip
New clutch @ 113k
Quaife LSD
Fidanza Flywheel
White Faced Gauges
BAT intake pipe
I did have the Juice
Poor excuse for a car owner =o(
IbeKrusty@aol.com
#45695 10/04/01 01:09 AM
Talkin about the Idler pulley, it seems to have gotten louder lately.
I know exactly what your talkin about with the socket. Very limited space, I haven't quite figured out how i'm going to get it installed yet.
Where did you purchase yours from? Do you have the part #, just want to make sure I get the right thing. Alot of ppl mistake the two, Idler pulley and Tensioner pulley.
Thanks for the help
Justin
Justin
1998 Black SVT
#45696 10/04/01 02:02 AM
Hmm...what I am getting on my 99 svt with 60K is this:
At 2K in gear only I get this cricketing sound that runs until about 2300. I did look at the belt and it does look very crappy, lots of cracks and not the normal wear ones either.
I am not sure if replacing the belt will fix the problem...I should check to see how loose it is.
Andrew
99 SVT
#45697 10/04/01 06:07 AM
same problem, replaced mine at 140,000km. and I notice how quiet our engine was after the fix. good luck!
#45698 10/05/01 06:27 PM
So where did you guys buy yours from and how much?
Part #?
Thanks,
Justin
Justin
1998 Black SVT
#45699 10/06/01 05:55 AM
$40 Canadian installed
#45700 10/06/01 04:31 PM
Part#?
Justin
1998 Black SVT
#45701 10/09/01 04:56 PM
t
Justin
1998 Black SVT
#45702 10/09/01 05:42 PM
Where is this idler pully...cause i have a strange chain like sound coming from my engine bay also and it drives me crazy..does anyone have an engine bay pic so u can show me where the sound is coming from...mine comes from the upper portion of the engine near the passeger side of the firwall...enclosed on in the black casing on the side of the engine...near the cams
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill|
Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
