Posts: 2,066 |
I have a grinding sound coming from my engine bay. I believe I have actually narrowed it down to the idler pulley. It almost sounds as if the bearings have gone bad.
Its tied to rpms, if the rpms go up the sound increases in frequency as well.
My question is: Is this common? and if I replace the Idler pulley does it come with the bearings? Could it be something attached to the idler pulley. All I really know is thats where the sound is coming from.
Thanks, Justin
Posts: 377 |
Are you talking about the idler pulley or the tensioner pulley? I also have a grinding noise from my idler pully. I bought the pulley, it cost $25 i think, and it does come with bearings already installed. I however haven't installed it yet cause i don't have the time or any wrenches, cause you can't fit a socket wrench to it. Hope i answered your questions.
95 SE MTX Throttle Hang Fix Fogs come one with Parking lights Custom exhaust(no res) 17" White Axis Touring Cup Perili P7000 Supersports KKM Sport Induction Windows tinted 15% EIBACH Springs Superchip New clutch @ 113k Quaife LSD Fidanza Flywheel White Faced Gauges BAT intake pipe I did have the Juice Poor excuse for a car owner =o( IbeKrusty@aol.com
Posts: 2,066 |
Talkin about the Idler pulley, it seems to have gotten louder lately.
I know exactly what your talkin about with the socket. Very limited space, I haven't quite figured out how i'm going to get it installed yet.
Where did you purchase yours from? Do you have the part #, just want to make sure I get the right thing. Alot of ppl mistake the two, Idler pulley and Tensioner pulley.
Thanks for the help Justin
Posts: 770 |
Hmm...what I am getting on my 99 svt with 60K is this:
At 2K in gear only I get this cricketing sound that runs until about 2300. I did look at the belt and it does look very crappy, lots of cracks and not the normal wear ones either.
I am not sure if replacing the belt will fix the problem...I should check to see how loose it is.
Andrew 99 SVT
Posts: 83 |
same problem, replaced mine at 140,000km. and I notice how quiet our engine was after the fix. good luck!
Posts: 2,066 |
So where did you guys buy yours from and how much? Part #?
Thanks, Justin
Posts: 83 |
Posts: 2,066 |
Posts: 2,066 |
Posts: 539 |
Where is this idler pully...cause i have a strange chain like sound coming from my engine bay also and it drives me crazy..does anyone have an engine bay pic so u can show me where the sound is coming from...mine comes from the upper portion of the engine near the passeger side of the firwall...enclosed on in the black casing on the side of the engine...near the cams
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill| Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
