Posts: 471 |
I want to maintain the ride height I have, but want to stiffen struts and springs. Any options? Thanks for the help.
Ed 95LX
Posts: 1,444 |
i feel the same. i think going with konis and ground control coilovers will allow u to adjust the height to stock with benefit of stiffer springs and damper adjustable konis
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 1,181 |
Strut tower braces will also help.
98 Merc. Mystique LS
Red Wings and US Soccer 0wn j00!
Master P
Master P
Posts: 5,455 |
Another option is 95SE struts and springs.. You may notice a slightly lower stance, but nothing very drastic (I compared my 96GL to a 95SE and the fender gap on the SE was less).
Posts: 3,248 |
1) bigger antiroll bars (the aftermarket 21, 22, 24mm rears and factory 19mm rear, 20mm front will reduce body roll without affecting ride height.
2) the BAT sport springs are only 1" drop.
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 960 |
Putting 99 SVT struts and springs into my 96 LX stiffened things up with minimal drop. Check the classifieds for used stuff.
96LX/24V/ATX/Midnight Red/A4 repeaters/SVT exhaust/KKM/65mm throttlebody/SVTsprings and ST200 struts/SE rockers and BAT spoiler/BAT 19mm swaybar/urethane bushings/Kenwood 7 speaker syst./E1 SVT brakes w Powerslot rotors/9005 lowbeams/885 fogs/50% tint/Michelin XM+S 130's for winter/E1's with gForces for summer...and now "New Paint!!" 87 Renault GTA convertible/2.0l/mtx/Sony sound/otherwise stock http://members.shaw.ca/neilmc/
Posts: 83 |
I have see an advertisment on a Taiwai car magazine. The product looks like a bump stop (the rubber sit inside the strut). It's a bit longer than the factory one and it fills up the gap. It said with those on, the conering will be improve. Don't know if it made for our car or it's available here, just remember that idea and share with you guys.
