Posts: 1,041 |
My trunk will not get rid of the rattles and squeakes anybody have a solution for me, other than cutting the rear of my car off. Need some help from you Suspension Tech's.
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
Posts: 100 |
Can it be the sub-frame? My car did that to me once. Ron
95SE,Duratec, Teal, MTX, Tinted, 50w Halogen Back Up light, 30Watts/8Watts Halogen Stop/Turn Bulbs Ford's Synt.Gold Tranny Fluid, 4X Toyo FZ4, Mystique Wheels. KKM Induction, Synthetic Power Steering Fluid, SVT exhaust.Painted Calliper Leather Shifter/Hand-Brake Boot Bigger oil Filter Ford's FL882
Posts: 661 |
You need to provide a little more detail. Squeaks are usually sway bar bushings, rattles could be bushings, collars, brackets and on and on...
Technical Director/Co-Owner Performance Fords-check out our new throttle body service 95 SE with lots of custom 1 off mods. All design, fabrication and installation by owner.
Posts: 1,041 |
Ok I do get some squeaking from the sway bar bushings... Other than that sounds like crap when im driving over a bump or ruffer terrain.
Posts: 64 |
I had a squeak from my rear suspension, but only when it was below 50deg outside. Turned out to be the emergency brake cable rubber shield rubbing against the trailing arm. A slight adjustment of the pan-tie and the squeaking was gone. You may want to check that. Otherwise, check all points that move under the rear. Just work on one set of points at a time to isolate the problem. Good luck.
Ted 86 SVO Mustang 98 SVT E1 Contour
Posts: 2,906 |
Since installing the aussie bar I have experienced many new squeeks. Possible that the upper half is flexing now...
Josh Aka Spectra SVT 02 Dark Highland Green F-150 XLT Mods: Gunrack and cowboy boots
Posts: 1,038 |
rear strut bar solve this? great, another way to blow my paycheck
Posts: 743 |
i have a squeeking too and my the rear-drivers side looks like its lowered almost...looked at the spring and its fine so im thinking struts...when struts are dying do they squeek alot and is it possible they would make the car lower?
Posts: 626 |
My rear struts have been squeaky since I bought the car 2 1/2 years ago. I have heard this is a common problem with the 98's
1996 Accord EX
"I am a disaster waiting to happen......"
Posts: 1,041 |
LIL SVT: Unless you changed the suspenison, you should be OK. Except for the the right rear side of your car will get a squeak, i heard was from fuel filter or something. (Just grease it up)
