Posts: 705 |
Jsmith and all, I've been itchin to construct an intake pipe. I've got some ideas but I want your input. What are the pipe dimensions at the ends? 60mm-70mm? What do those measurements convert to in English? What are your thoughts about using actual exhaust piping like this guy did? Intake Specifically these pics: Also using the max size diameter piping to allow for the gromets and the minimal tubing masses in the intake pipe and funneling down at the throttle pipe, like this: Is there any danger in using aluminized steel in the pipe? Any input would be great, maybe we can come up with a list of materials and a how-to.
Ryan Toreador Red 1998 SVT #2843
"Performance in the hands of few"
Posts: 3,567 |
my pipe I made is aluminized steel. I don't think that theres reason to be concerned about the aluminum flaking off since it doesn't flake off exhaust pipes.
I have no idea what the size of the pipes are in metric, but when I built mine I used an exhasut pipe adapter. 3"OD - 2 1/2"OD then I bought an adapter where one side was 2 1/2 ID which slips over the 2 1/2 OD side. I cut the other end of the adapter off and welded the cut piece right over the small end of tha adapter effecticely increasing its outside diameter. Once that was done I cut the tube to length leaving room for about 1/4" gap between both the TB and the MAF.
Idealy you want a tube that is 3" OD on one end and 2 1/2 ID on the other end. The inside diameters of both ends of the tube are the exact size or slightly larger than the bores of the MAF and TB respectively.
I thought about using gromets to seal the tubes to the intake pipe. That would likely be fine since the tube is just a connection betweent the MAF and the TB and it is not subjected to high or low pressures. I decided to weld everything becasue it ensures a perfect seal and it is much stronger than a gromet. Becase if air leaks through a gromet or any place on the tube it will be air leaking in that has not been metered by the MAF.
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
Posts: 705 |
Jay can you post some pics or email me at malone3 *@* gis.net? I bought a 2 1/2" pipe today and as had a thought today about sleeving the inside of the current rubber pipe. Any thoughts?
Posts: 705 |
Jay, the 2" rubber fit over the 2 1/2" ID Pipe? I went to lowes today looking for a 2 1/2" rubber hose but that is not a standard tubing size. I did however see a 3" to 2" adatper, and if the 2" fits over the TB than I'll be psyched cuz I'll just get a 3"x3" Fernco a 3" exhaust pipe, gromets for the inlets and a 3"x2" Fernco reduction tube.
Posts: 3,567 |
when you put the fernco over the MAF and the 3" pipe you will at first be bummed becasue it will fit like a broom stick in a barrel, but my friend who is a pluber reassured me and said it will fit. I closed down the clamps and low and behold it fits. The 2 1/2 fernco I used to connect between the small end of the tube and the trottle body they fit tight, infact I had a difficult time because the fit was so tight, but finally a thin film of vasoiline did the trick.
Because of size limitations I was able to use the entire 2 1/2 fernco on the small end of the pipe, but for the large end where I used the 3" fernco I had to cut it in half. I cut it exactly in half and it fit pretty good. The tough part is cutting it. I tried a razor and it broke, I tried a utility knife and I almost slaughtered myself, so I used a hacksaw. What I ended up doing to ensure a nice straight cut was to remove the clamps and put the adapter in a vise and clamp it down all the way, then cut the adapter. I used a 32 teeth per inch balde and it made a clean cut, I just removed all the burrs and crap by just yanking them off.
