Posts: 22 |
dose anyone get heavy fog or moister on the windshild , some days it gets so bad i need to pull over , even with defroster on.
96 2.0 mtx kenwood deck & amp,mtx cr, boston acustics,12inch phonix gold 45sq feet vibration dampning/sound proofing 15%tint 98 rims ,fire gta's factory tack install k&n ,intake res removed accle thunder , ngk custom exsaust redline/fm , waterwetter , sy oil& stp svt mounts jet chip
Posts: 498 |
Could your heater core be leaking?
{I do hate spam, but that isn't really part of my email address. Remove the string ?HatesSpam? from the email address ?BobHatesSpam@blaylock.to? to email me. No advertisements. Spammers will be dealt with very harshly!} ------- Moonlight Blue 1996 Mercury Mystique GS , Zetec engine, ATX. No mods. (Well, OK, one mod. Before I got rid of my previous car, a 1994 Tempo, I swapped radios. I liked the Tempo's radio better. That counts as a mod, doesn't it? I also kept one of my Tempo's wheels to use as a spare. I hate those stupid ?compact? spares that come with modern cars. Does this count as a mod? If so, I guess I have two mods. Replaced burned/melted blower switch and connector on 19 February 2002 with a 1P3T toggle switch from Marvac and a Molex connector from Rat Shack; I guess this now makes three mods.)
Posts: 1,041 |
I get that only on the front right side windshield.
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
Posts: 5,805 |
Have the AC pressure checked/topped up.With low AC charge the 'drier' part of the ac,which is used on 'heat' settings,will not extract the moisture from the inside of the car.
Posts: 64 |
I would have to agree with Bob's diagnosis. Does the smell of the air out of the vents smell sweet? If so, your heater core has given up the ghost. If the heater box is anything like a Mustang's then you are in a long DIY project or a heafty shop bill.
The only other things I can think of are a water logged air cabin filter or a clogged evaporater drain line that is not allowing the coil condensation to drain out of the heater box. HTH.
Ted 86 SVO Mustang 98 SVT E1 Contour
Posts: 1,770 |
Could potentially be a bad windshield seal in that area.
Posts: 22 |
got no ac , a new cabin filter ,heater cores still good and all seals look good to me witch was the first i looked at cause the temp diff inside to out will do this ,but it's not that , seen another contour do it to. cant figure this one out
Posts: 2,809 |
Has anyone ever driven by a river or lake, in the early morning, and have their windshield fog up SOOOO BAD...defrost on high helps a total fog out. I get that every morning right at the same spot in Westport MA. I too thought it was a problem with the car but have noticed it happens on the same stretch of road.....only on cold mornings. Just a thought.
Posts: 22 |
well , it never happens in summer but any other time of year i always have def on to help , but still dosent get it all and vision is bad , night is the worst.
Posts: 351 |
I have noticed that after I Armor All the dash, in the heat the Vinyl protectant evaporates and fogs the windshield.
A thought.
98 Contour LX V6 Mtx
