Posts: 45 |
I have 2 ford filters in my garage, one says "made in Canada" and the other says "made in USA". The Canadian one is glossy white has M22 stamped on it and has 8 large holes around the perimeter. The made in USA filter is a dull white color with ZZ stamped on it and it only has 6 smaller holes around the perimeter. Both were bought at the same dealership. The one that says "made in Canada looks like a better filter because of the larger holes both inside and outside the filter. I don't understand why they would be different.
Posts: 1,421 |
frank could u describe the inside of the 2 filters 2 me,i hope they switched 2 the purolators not 2 fram crap ass filters,if u like the wix filters both uap and carquest sell them 4 cheapeer then ford does
97 gsxr lotsa good stuff 4 sale 95 talon tsi awd turbo loaded sold 95 se 2.5 mtx loaded (fragile handle with care)2 motors 3 trannies custom y with hi flo cat,custom dynomax exhaust,upper cat mod superchip,udp,bat\kkm,proflow maf,ford 9mm wires,svt throttle body,svt intake manifold ,custom kevlar clutch,16 pd. flywheel,svt motor mounts ,svt gauges,eibachs\h&r,omp strut brace,dark chrome 16" rials with 225/50 dunlops,cwazy amounts of audio
Posts: 45 |
Roland, I now have the filters in front of me and they are as I have described above. The one that says "made in Canada" looks like it is a better filter then the one that says "made in USA". The holes around the perimeter are much larger and there are 8 of them instead of the 6 smaller holes on the "made in USA' filter. Looking inside the filter the "made in Canada" filter again has larger holes and it appears to also have more holes. Both filters were bought at the same place but at different times. Bothe part # FL-820S.
Posts: 1,421 |
do they both have the cylinder inside with the oval hole in it
Posts: 45 |
Originally posted by roland stiller: do they both have the cylinder inside with the oval hole in it From what I can see everything inside both filters are round. Nothing in either filter looks oval. Maybe it just seems oval when you look at it at an angle.
Posts: 100 |
I never saw the oval holes ? A third supplier? Every supplier have to meet Ford's specification any oil filter with Ford's name for a specific application must have similar characteristic so it's not a tragedy to have different supplier for what i know every compagnies are doing that. Anyway if you want K&N oil filter go to "Canadian Tires" you can have them special order the next day for 16 or 17$ CND Part# HP-2010 Ron
95SE,Duratec, Teal, MTX, Tinted, 50w Halogen Back Up light, 30Watts/8Watts Halogen Stop/Turn Bulbs Ford's Synt.Gold Tranny Fluid, 4X Toyo FZ4, Mystique Wheels. KKM Induction, Synthetic Power Steering Fluid, SVT exhaust.Painted Calliper Leather Shifter/Hand-Brake Boot Bigger oil Filter Ford's FL882
Posts: 179 |
Originally posted by roland stiller: in ont. we are still getting the wix,u can tell a wix by the strange lil round cylinder with the oval hole in it on the inside of the filter.but i'd gladly pay u 4 a habitat du canadiens version ron e-mail me @ rolandstiller@hotmail.com Roland, I just picked up a FL820S from a dealer in Mississauga and it is Made in USA. The parts guy (my brother-in-law) said that they just switched on the last shipment. This was at Whiteoaks on Mavis Rd. I'm not sure now whether to use it or not! // Chris Root // '99 SVT
Posts: 1,421 |
i picked one up the other day they r the same as the ac delco filters i've been using 4 aawhile now,they r the same filter they buse in the vets so i'd imagine trhey r pretty good
Posts: 1,421 |
Posts: 425 |
Errr... the engine? Because of the timing chain issue? Let us know! I have the same noise!
Thanks Sam
I heed the call of the curb
