Posts: 3,248 |
At a suggestion I emailed yet another racer about the oil starvation. Answers similar to the Reinke, Mirko, Bondurant responses.
Barry, > My name is Dan Nixon and myself and several other from the CEG are > trying to figure out the reason that several persons have had "spun" > bearings from what may be oil starvation . Some cases have > been related > to hard right turns (offramp, track events), some high RPMs, but > occasionally no apparent stress. Most of these episodes > (probably 15-20 > have been described are on the street and often low mileage (say 40K > miles) without admitted low oil levels or lack of maintainence. > > Some have suggested the oil pan needs baffles, or that it needs > screens to breakup aeration or windage tray changes. I saw that you > group developed a windowed pan which I was hoping might have shed some > light (literally) on the problem. Have you had any oil related issues > or learned the cause(s)? If so, any solutions - redesigned pan, > accusump etc. We are talking street use here in my case, I > may do some > SoloII but that's it. I've personally had no problems with my Contour > SVT but would like to keep it that way. Any help greatly > appreciated.
OK, on the oil thing ... we knew, from other forms of racing, that at certain tracks, e.g. Road Atlanta, we WOULD have oiling problems. The oil (on any stock, wet sump engine), will "stand up" the side of the pan and block under certain conditions, exposing the oil pickup, and temporarily starving the engine of oil. Not a good thing. In addition, when that oil "stands up", it will most likely hit the crankshaft, causing windage and power drops.
SO, we baffled the pan right out of the chute....building a more extensive windage tray, putting in some baffling (no spring loaded trap doors) AND deepening the sump (we "squared" the pan off near the xalxe bellhousing).
In addition, we run a 3 quart accusump. Even with all the pan mods, we still saw some oil pressure fluctuation until we used the accusump.
So, for the street, I'd recommend a stock pan with the accusump. The accusump will handle the situations you'd likely encounter (or in Solo)....and it's a LOT less $ than a modified pan.
> > Just out of curiosity, how much power are you squeezing out of the > Duratec (if I can ask). We're making greater than 120hp/liter
FYI, 120HP/L is 300HP from the N/A 2.5L!
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 532 |
300 hp??? GIMMEE
Dave
99 T-Red&Tan SVT/high flow res/K&N/painted grills & calipers/V-one/tinted windows/baby seat #2228
93 Escort GT Automatic (need I say more ->> it's the wife's car)
"I like long walks, especially when they are taken by people who annoy me"
Posts: 7,329 |
Originally posted by Dan Nixon: We're making greater than 120hp/liter
FYI, 120HP/L is 300HP from the N/A 2.5L! ahhh.... Excuse my puddle of drool... That embarrasses a lot of forced induction cars!!! Accusump they say... Anyone find a good place to mount it? (sans battery relocation)
Posts: 2,061 |
I'm thinking the accusump needs to go where the Cabin-air filter is. I think there is enough room in there and I dunno about you. But I can manage to breathe without that piece.
Dave Andrews Black&Tan 2000 SVT 225 of 2150 Bassani.. UNCORKED davelandrews@comcast.net "Nothing is so firmly believed as what we least know." -Montaigne
Posts: 329 |
Originally posted by DemonSVT: ahhh.... Excuse my puddle of drool... That embarrasses a lot of forced induction cars!!!
Accusump they say... Anyone find a good place to mount it? (sans battery relocation) It would be nice to have their cam grinders phone number!!!!
blk.99svt n.e.Ohio Never under estimate the power of stupid people in large groups...
Posts: 206 |
I was all hot to buy an accusump a month ago and then decided that I would tempt fate once more at the track without it, but this time with an oil gauge an warning buzzer to alert me to drops in oil pressure below a preset level - I'll let you know how it goes.
As for mounting location, I built a cardboard model of the 12" long accusump (4.5" diameter IIRC, but going from memory here) and found that there was enough room to mount it right below the battery. Not the easiest place to get to to put the air charge in, but hopefully that's something you do once per year. It was going to be tight and looked like in the worst case it may take a file to remove <0.5 mm from the bracket that holds the battery. What was going to take a bit of effort, regardless where you put it, was to figure out how to physically mount the thing - probably going to involve drilling some holes somewhere.
By the way, Canton had a price that was just marginally better than BAT, but not by a significant amount.
Eric
Posts: 9 |
Posts: 1,692 |
NoFordsAgain quit cross posting... you have posted this in more than one section congrats you know how to type and copy and paste it to different post...
Joe Hartley "yes I know it's a MTX Zetec but it beats having a ATX Duratec" Champagne 96 GL MTX some mods dynoed at 114.2whp and 124.4wtq (pre CTA intake) 16.858 @ 80.76mph (yes it's slow but still faster than D Davis) AIM: ZetecRacing My Site My Profile
Posts: 2,375 |
he he and your following him around too!
Posts: 653 |
Is that 120hp/l on a purpose built race engine? Even so, drop some hints as gow to get there with n/a.
Mike
I have a dream, and that is a 69 Boss 302 with Jules Asner in it. Current - 2002 Chevy Silverado Former - 98 SVT E0 T-Red 4/4/97 #173 of 6535(so long girl, you'll be missed)
