Would it be too much trouble to ask you to weigh the stock /vs upgraded parts per wheel? I'm thinking about the willwoods mainly because the bear kit looks heavy esp. with the one piece rotors and they were known to cause a gyroscopic effect on miata's (yeah i know you can't compare a 2400lb car to a 3000lb one but...). I'm very interested in the weight diff. Ohh and don't forget to add some extra padding on the windscreen
98 SE BAT Big Brake Kit "C", Throttle Hang Fix, B&M Shifter, Lightly Cracked Secondaries, BAT Euro Handling Kit, 20% tint, Removed Ding Strips, ES Motor Mount Inserts, Borla CatBack, Apexi SAFC, HighTower Rear Brace, BAT 19mm rear bar, MSDS Headers & Y, AFE 20-35008 filter, ClutchMasters Stage 1, Fidanza FlyWheel, SVT T.B. ====OnOrder==== svt uppers and lowers,
