Page 2 of 2 1 2
4
4
99M08 is the program number that covered this problem on my '98 in Jan. of this year. It should cover the '99s as well.
Justin
'02 Ranger Edge ext cab
Retired: 98.5 Mystique
It takes about 10 min of your time & about 10 bucks to take care of the problem yourself by replacing the fan-speed resistor pack. The unit usually cracks (why?) confused & breaks internal connections.
Is the smoke alarm in your house also known as the "dinner bell"?
'99 Zetec VCT Daily Driver
Mild Air Filter Mod
Here's a How To change the resistor pack on the Mondeo site under common problems:-
http://www.fordmondeo.org/
5 Dr, 2.5 V6 Ghia X, 1999
Modifications:-
Inventor of the inductive Secondary monitor
Chrome grill
JR cone air filter
Black Diamond cross-drilled & grooved discs with Predator pads,
ST200 throttle body, upper and lower extrude-honed intake manifolds
Scorpion s/steel exhaust
Current Project.. Building a ST200 powered MKI
paullorman@btopenworld.com
The AC on my 98 SVT would only blow on high, then I received a letter in the mail saying it's recalled then I brought it to Ford and done. In fact the actual letter states " Ford is providing an additional coverage program number 99M07 to owners of certain 1995 through 1998 Model Year Ford Contour and Mercury Mystique vehicles" further down the letter " Ford Motor Company is providing additonal coverage on the heater blower switch,resistor and attached wire connectors" and that was straight from the letter. So if you have a 99 then I don't know if it's covered.
that is too weird, mine just did same thing today, i was drivin along and i realize that the fan aint blowin no more, only on high, i have a 98, i bought it privately can i still take it too a ford dealer and get them to replace it?? (the previous owner got it from a SVT dealer)
95 SE Champagne Mettalic
True Dual exhaust with X pipe and Redline mufflers
KKM Tru Rev intake
H&R Springs/KYB struts
Apex-i S-AFC
65mm Throttle Body
17" Ace Spades
4 Pt Racing Harness
Window Tint all around
New Engine @ 117k kilometers
G-Tech: 15.6 @ 91.5 MPH
"you officially kick ass"
quote from awed CEG'er after i chopped my hood and threw on scoops
RIP 98 SVT silverfrost *nov 4 2001*
5 year 120 000kms! If your car falls in this area you should be covered! CAll Ford Kris!
2001 Cavalier
150-175 more kms
per tank of same size
Pioneer 12 CD Changer
SOLD Green 98 Mystique
GS Sport
Zetec ,ATX
885 Fogs mod.
Hi beam mod.
205 15s
GMATT Offline OP
Thanks again, everybody. I'll try the dealer again, although another trip to the dealer is always another chance for a f**k up. $10 for the resistor pack sounds good to me to avoid the dealer! If it's the switch/fuse/relay, that's a different story.
Greg
99 SVT Tropic/Tan
#1332
Page 2 of 2 1 2
