Page 2 of 2 1 2
Wow, How lame that Ford didn't fix that problem in the later models. I had the problem corrected under warranty on my 95 GL 2.0L in 1997...
I kinda have that prob. When I go to get gas I have to play with the nozzle and move it at different angles to get it to take the gas in.
Claudette
2000 SVT Contour
TrueStreetPerformance
AIM: SVTChic and/or CobraChic96
2000 SVT Contour #412 of 2150
Born on 11/18/99
Claudette
2000 SVT Contour
Born on 11/18/99 Died 10/31/01
Claudette
2000 SVT Contour
Born on 11/18/99
Claudette
2000 SVT Contour
Just had this happen to me the last two days. Really freaked me out, first thought I just picked a bad gas pump at the station, but I got pretty worried when it happened again tonight when I went to fill it up the rest of the way.
Came home and did a search here and found this right away. Thanks CEG! laugh
Unfortunately it is too hot during the summer in missouri to deal with 'oops I can't fill my gas tank now' bs. So now I'll be dealing with a @#$%#ing ford dealer, what are the chances of them actually getting it right on the first try even if I can give them the specific tsb number? I wouldn't put money on it. mad
-CtrAltDel
'00 SVT Contour
Silver Frost/Midnight Blue
#794/2150 12/8/99
I have this problem and I have had it in the Ford Dealership twice now and apparently they can't fix the damn problem!
My Fuel Gauge also reads very inaccuratly! One seconde I'll have a half of a tank and the next second it will be below E and the fuel light will be on. Is this related or is it just the fuel sender going bad? What do I need to do if so?
Thanks in advance...and I guess I'll be going in for a third time to try and get it fixed!
Later
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
bttt
Justin
1998 Black SVT
Originally posted by krazyksvt:
OK - I'm almost embarrassed to post this, but thought there might be some rational explanation out there. In the last 2 days I have been unable to fill my gas tank. Any pump (I've tried many) will shut off like the tank is full(it?s 1/2 full- ~200 miles since fill up). I've tried running the pump as slow as possible and nothing! Is the tank pressurized? Could there be something causing back pressure?
Hey, I live in Alexandria and I have the same problem. I think the regulations on emissions here is part of it...the pumps all have those fume stopper thingys on them and some tend to be really sensitive to back pressure. I deal with it by not quite fully inserting the nozzle (sort of dangerous on its own, I know), not using the auto-fill lever, and just being patient. frown
I used to have the problem on my 95, I learned how to hold the pump a certain way and it would work like a charm...unfortunatley, the NJ gas station attendants were dumb, and would have a fit if i tried to pump it myself!
I have had the same problem on my 99 SVT. Only on really hot days. Unexplainable. It only happens with some pumps though.
1999 Silver Frost SVT
#609 of 2760
Born on 12/3/98
KKM Intake
Removed Resonator
35% Window Tint all around
Tinted Tail Lights
ElKy Mesh Grilles
HID
Dyno'ed at 175.3HP/155.5TQ
V
V
Yes this is a common annoyance.
Here is a tip:
When inserting the nozzle, be sure not to insert with full force and don't press it up against the gas tank. I always thought it was a good idea to press it up to create a "seal" with the rubber surround of the nozzle...instead just insert it like 4/5 of the way inside...pretty much all the way but not completely... (make sure it IS inside tho! laugh ) and its should be MUCH easier to fill your tank up.
1998 E0 Ford Contour SVT
Built on 8/19/97 -- #3101/6535
* New Cupholders * CEG sticker =) * 9005 Philips BlueVisions * Sound System: Kenwood eXcelon KDC-X617 HU, RFosgate fnq514 components, RFosgate 6x9 3ways, RFosgate 12" sub, MTX 5ch/800w amp, 1 Farad Cap * Removed Ford emblems * Fogs w/parking lights and aimed up * Brushed Aluminum Style Grills all around * 205/55/ZR16 Bridgestone Potenza RE730's * Removed Headliner * Visit MY SVT website (UNDER CONSTRUCTION)*
F
F
Before the TSB was issued I carried a piece of 3/16" nylon tubing 55" long. When it would act up I'd slide that the fill until it met with resistance. Then I'd jab it back & forth and loosen the Flapper. One day I didn't have it in the trunk, however I had an antenna element Stainless steel well in my rage I do believe I broke the flapper off. Been 2 years NO problems!!!!!
Beside the little flapper the size of a quarter, well it looks like a prize in a box of Cracker Jacks.
Paul
98 Mystique LS
Page 2 of 2 1 2
