#383329 02/24/02 01:17 PM
jarmijo Offline OP
Hey guys, when in gear my shifter is so loose it's like it's in neutral. Any ideas on what it would take to clean this up some? I'm hoping it's just some bushings or something. Any help would be appreciated.
Jack
'99 Silver Frost SVT
Borla Cat-Back
UR UDP
B&M Edge
HPP Rear Upper Strut Bar
Random Tech Front Upper Strut Bar in Garage
SHM Headers in the garage
Hood struts in garage
Audi side markers in garage
#383330 02/24/02 03:02 PM
W
W
It's most likely the connector bushings on the cables or the ball joint getting sloppy. You have to pull the shift boot cover off and examine how much play there is right there at the ball and also where the cables connect up. Then there is also the cable connections at the trans.
I would start inside and work your way outside.
My guess is the cables. Do you have more side to side play in one direction(forward and back) than the other (side to side) or vice versa?
warmonger
You can call me anything you like as long as it's nice.(all lies accepted)
99 Silver Frost SVT. #226 of 2760
Engine: 3.0 power!
Unique Stuff: Sunroof control module (#1 of 9)
Car Audio: Loaded and loud!
Check them out at
http://home.earthlink.net/~twilson1726
#383331 02/25/02 04:37 AM
YOu may just have loose bolts on the shifter. Pop off the boot and use a torx bit to check it out. The stock shifter was always a bit sloppy for my taste. Try a B+M and you won't be sorry.
Po-Jay
Ghetto Mods Galore!
Quaife-CenterForce Clutch-Butterflies Rmvd and Replaced again-Bassani Exhaust w/custom "Y"-Pipe-33% of Mystery Mod-Pro M 75MM MAF-BNoon Optimized SVT TB-B+M Short Throw-ES Front Engine Mount-Some Aesthetic Crap-
Blood,Sweat,Tears
Do I hear the Fat Lady singing?
98 E0 Silver Frost (Is there any other color?)
172HP 149TQ W/Bad A/F Mix
#383332 02/28/02 02:16 PM
jarmijo Offline OP
Thanks for the help guys, I'll look try some of these suggestions this weekend. Warmonger, the majority of the play is side-to-side or right to left as opposed to up-and-down. Po-Jay, I already have a B&M and have had it for over a year now. Thanks again guys.
Jack
Borla Cat-Back
UR UDP
B&M Edge
#383333 02/28/02 03:44 PM
Duh, I never read your sig... sorry.
Po-Jay
Ghetto Mods Galore!
Blood,Sweat,Tears
#383334 02/28/02 07:32 PM
I
I
Hey Po-Jay
You might want to get the shifter re-welded before it goes out. I was the first to learn the hard way. mad
B&M Shifter Problem
99 Range Rover 4.6 HSE
Mystery Car??????
#383335 02/28/02 09:53 PM
Thanks dude, I will look into it. I have installed and un-installed the shifter 3 or more times, due to various tranny warranty work. I assumed that they (Ford) would (try to)void my warranty if I left it in during the shop visit. I haven't noticed the problem, but I wasn't worried about it then. I assume that the piece in question is the ball and post that attaches to the shift linkage via snap joint... Right???
Po-Jay
Ghetto Mods Galore!
Blood,Sweat,Tears
#383336 02/28/02 11:46 PM
I
I
Correct! The new welds Terry had put in place made shifting tight and easy. I suggest welding it soon...really soon!
Mystery Car??????
Moderated by  Keyser Soze
