Posts: 1,847 |
95 Contour SE ATX V6 "Cracked" Secondaries DMD Installed SVT Brakes
Posts: 3,237 |
Go to Autozone and rent a belt tensioner tool. It's a steel plate with a socket end on it to fit in tight places.
Posts: 1,847 |
How did everyone else seem to use a 3/8 breaker bar? From what I am seeing, it would be impossible to insert in the tensioner socket. Perhaps this only affects ATX cars, meaning that our engine must sit a litte more toward the passenger side than the MTX cars? As is, there is absolutely no way to get any breaker bar in there. I know what tool you are talking about, I was just pissed earlier. Guess I have to put everything back together and head to AZ again...  :rolleyes:
Posts: 9 |
I was able to remove the belt my removing the splash shields behind the wheel and reaching the tensioner with a 3/8" ratchet from underneath. Very easy to get at this way.
Posts: 1,859 |
**HELP SAVE CEG!!! DONATE NOW!!!**
*This space for rent* Please call... 1-800-FOR-ELKY
All proceeds go towards saving CEG
Posts: 1,847 |
Originally posted by blaster040: I was able to remove the belt my removing the splash shields behind the wheel and reaching the tensioner with a 3/8" ratchet from underneath. Very easy to get at this way. Been there, tried that. It's not that I can't get a rachet or breaker bar to the tensioner, either from above or below. It's that the tensioner sits so close to the frame that there is no room to insert the breaker or ratchet in the socket of the tensioner. If I did get it in, it would forever be stuck there (and no, don't quote that you sickos  )
Posts: 153 |
That sides motor mount is different IIRC for 98+, and there appears to be more room in that area on those cars. There was no way in h@ll I was getting a breaker bar in there on my 97 anyway. From under the car, there is a lip or ledge on the bottom of the tensioner. With a large flat blade screw driver it is pretty easy to get it on that and push up to release tension. Then slide the belt of just one pully and you are good to go.
97 SE MTX, KKM, UR UDP, 19# Injectors, SVT TB, SVT UIM, SVT Flywheel, Grizzly Street Clutch, Upgraded motor mounts, mystifed precats, brand new main cat, SVT exhaust sans resonator, 205-55-15 Dunlop SP5000's 154hp / 156 tq before the SVT exhaust, SVT dual honed upper and swapping the mystery main cat for mystery precats. My Profile
Posts: 237 |
1996 Contour SE Sedan 4D (Royal Blue) Duratec V6 2.5L 24-valve DOHC Automatic 75,000 miles No Mods (unless you call the DMD a mod) Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
Posts: 1,847 |
Well, I got it done. Had to wait for the wife to get home from work with the van so I could go to AZ to rent the tool. Between that and eating dinner, I finally got done. It worked, but I had to get to it from the top. The tool was so long that it contacted the lower control arm and there was no room to relieve tension. This mod is a serious PITA on an ATX. The only way I could "lock" the engine was by using a socket and driver on one of the torque convertor to flexplate nuts. It took a lot of muscle to break the factory torque on the damper bolt. I could't find the correct bolt for the installation tool, either. So, I ended up using both washers, various sockets, a box end wrench, and even the key to my locking lug nuts to make the bolt fit. It was a bit too short, but long enough that it would bottom out in the crank with certain socket/washer combos. At one point I even had a socket in a socket, using the larger one as a washer, lol. Perhaps it should be added to the FAQ that you will need access to the torque convertor to flex plate bolts for ATX cars, and Pre-98 cars will have clearance issues and will need to rent or buy a belt tensioner tool from Auto Zone. Oh, and I do notice a difference in the engine, though not as dramatic as some here would suggest. Perhaps it is because I have an automatic and the fluid filled torque convertor might act as a bit of a damper? (Fluidamper, anyone?  ). It would be interesting to see the number of engine failures for MTX cars vs ATX. I'd be willing to bet that the ATX cars are far below MTX's in failure rates. My engine failed, but I believe that was due to shoddy workmanship at the dealer when they fixed my oil leak (front main seal). I think they turned the engine counter clockwise and bound up the timing chain. Anyway, I used to feel a slight vibration in the floorboards above ~3200 RPMs. Now it is gone and the engine is electric motor smooth. Very nice indeed, well worth the mod.
Posts: 3,248 |
I'd be willing to bet that the ATX cars are far below MTX's in failure rates. agree but this is simply because ATX cars spend much less time at high RPM. Higher RPM = much worse crank whip. Non SVTs with MTX also probably less than SVT because peak power at lower RPM + slower reving = less time in the fun zone. Personally, Im not sure if DMD is needed with ATX (unless it has 200 HP and level 10 treatment...Ford has not installed DMD except on new MTX cars (I think).
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
