Posts: 206 |
CONTOUR ESSENTIAL INFORMATION
Much of this was compiled for a 1998 Contour SE w/2.5L, though the information should pertain to most Contiques. It may not be all encompassing, but hopefully useful anyway. I keep a printed copy in the glove compartment just in case.
IGNITION Spark plug - AWSF-32F Motorcraft - AWSF-32PP Motorcraft, Platinum - APP5344 Autolite Spark plug gap - 1.3mm Firing order - 1,4,2,5,3,6
Spark plug wires: Magnecor - 483-65153 (SP Motorsports p/n) Taylor - 072607
FILTERS Air filter - FA-1613 Motorcraft - CA7737 Fram - 33-2115 K&N (fits in stock airbox)
Passenger compartment air filter - FP4 Ford - C14860 Purolator Fuel filter - FG-800A Motorcraft Oil filter - FL-820 or FL-820S Motorcraft
OIL Engine oil 5w-30 - with filter 5.5 liter (5.8 qts) - without 5.0 liter (5.3 qts)
Manual Transmission oil, Mercon ATF - 2.7 qts (2.6 liter) Automatic Transmission oil, Mercon ATF - 10.2 qts (9.6 liter)
COOLING SYSTEM 9.5 liter (10.0 qts) Total capacity 9.7 liter (10.2 qts) with automatic transaxle
MISC. Battery BXT-40R Motorcraft PCV valve EV-152 Motorcraft Fuel tank 61.5 liter (16.3 gallons) Wiper Blades - Bosch or Anco; driver's side is 22" and the passenger side is 20" Remote Keyless Entry batteries - CR-2016 (2 req.)
WHEELS/TIRES Wheel lug nut torque - 62 lbs (revised to 90-100lbs by Ford)
Tires (your choice of speed rating): w/15" wheels - 205/60 x 15 (24.69" dia.) w/16" wheels - 215/50 x 16 (24.46" dia.) w/17" wheels - 215/45 x 17 (24.61" dia.) - 235/40 x 17 (24.40" dia.)
LIGHT BULBS Fog lamp bulb - Motorcraft F2DZ-13466-C - Sylvania 893 (38W)(stock rating) - Sylvania 885 (50W) Front turn signal - 3457 Headlight, high beam - 9005 Headlight, low beam - HB4 (9006) Rear tail/turn/brake lamp - 1157 Backup lamp - 1156 High mounted brake lamp - 2723 License plate lamp - C5W
FUSES ENGINE COMPARTMENT FUSE BOX Fuse #, Amp, Color, Circuit 1, 80, Black, Main power 2, 60, Yellow, Engine cooling fan 3, 60, Yellow, ABS braking system, Heater blower motor 4, 20, Yellow, Daytime running lights 5, 15, Light Blue, Fog lamp 6, Not used 7, 20, Yellow, ABS system 8, Not used 9, 20, Light Blue, ECU 10, 20, Light Blue, Ignition switch 11, 3, Violet, ECU memory 12, 15, Light Blue, Horn, Hazard flasher warning system 13, 20, Yellow, Oxygen sensor 14, 15, Light Blue, Fuel pump 15, 10, Red, Low beam, passenger side 16, 10, Red, Low beam, driver's side 17, 10, Red, High beam, passenger side 18, 10, Red, High beam, driver's side
PASSENGER COMPARTMENT FUSE BOX Fuse #, Amp, Color, Circuit 19, Not used 20, 10, Black, Wiper motors (circuit breaker) 21, 40, Orange, Power windows 22, 7.5, Brown, ABS module 23, 15, Light Blue, Backup lights 24, 15, Light Blue, Brake lights 25, 20, Yellow, Door locks 26, 7.5, Brown, Main light 27, 15, Light Blue, Cigarette lighter 28, 30, Light Green, Electric seats 29, 30, Light Green, Rear window defroster 30, 7.5, Brown, Engine management system 31, 7.5, Brown, Instrument panel illumination 32, 7.5, Brown, Radio 33, 7.5, Brown, Parking lamps - drivers side 34, 7.5, Brown, Interior lights, electric side mirrors, clock 35, 7.5, Brown, Parking lights - passenger side 36, 10, Red, Air bag 37, 30, Light Green, Heater blower motor 38, Not used
RELAYS ENGINE COMPARTMENT FUSE BOX Relay, Circuit R1, Daytime running lights R2, Radiator fan, high speed R3, Air conditioning R4, Air conditioning clutch R5, Radiator fan, low speed R6, Starter solenoid R7, Horn R8, Fuel pump R9, Headlight, low beam R10, Headlight, high beam R11, ECU module D1, Reverse voltage protection
PASSENGER COMPARTMENT FUSE B0X Relay, Circuit R12, Interior lighting R13, Rear window defroster R14, Heater blower motor R15, Wiper motor R16, Ignition D2, Reverse voltage protection
AUXILARY RELAYS (outside of fuse boxes) Relay, Circuit, Location R18, One Touch window switch (driver only), Drivers door R20, Not used R21, Not used R22, Foglights, Module bracket R23, Turn signals, Steering column R24, Panic alarm, drivers side, Door lock module bracket R25, Panic alarm, passenger side, Door lock module bracket R26, Not used
WHEEL ALIGNMENT SPECS
FRONT:
Caster: (not adjustable, for info only) Minimum: 1.4* Maximum: 3.4*
Camber: (not adjustable, for info only) Minimum: -1.9* Maximum: 0.8*
Toe: Minimum: -0.09* Maximum: 0.09*
REAR:
Camber: Minimum: -1.5* Maximum: 0.5*
Toe: Minimum: 0.00* Maximum: 0.28*
-Wes 98 SE Sport
[This message has been edited by wjang (edited April 25, 2001).]
Posts: 5,296 |
HUH? Camber and Caster? Aren't they non-adjustable? ------------------ AirKnight (Dominic Ho) Buffalo, NY
AIM: AirKnight on MTBMy BEAST
Posts: 206 |
You're right, they are non-adjustable. The only adjustment possible is the toe-in and toe-out. The specifications are for information only - useful when checking if your chassis/suspension components are damaged, like after an accident.
-Wes 98 SE Sport
Posts: 677 |
Excellent information there wjang! I know it will come in very handy for me. I too have printed it and am keeping one copy in my glovebox and a second copy in my Chilton manual. On behalf of everyone that will be using it I would just like to say Thanks....Good job!
------------------ 98.5 SE Sport badgeless, MTX, KKM, SVT exhaust with resonator intact. 1985 Z51 Vette with many mods. Only used when the Tour appears to be outclassed.
Posts: 960 |
Excellent except that Ford and most people here have revised the lug nut torque to 90 lb-ft.
96LX/24V/ATX/Midnight Red/A4 repeaters/SVT exhaust/KKM/65mm throttlebody/SVTsprings and ST200 struts/SE rockers and BAT spoiler/BAT 19mm swaybar/urethane bushings/Kenwood 7 speaker syst./E1 SVT brakes w Powerslot rotors/9005 lowbeams/885 fogs/50% tint/Michelin XM+S 130's for winter/E1's with gForces for summer...and now "New Paint!!" 87 Renault GTA convertible/2.0l/mtx/Sony sound/otherwise stock http://members.shaw.ca/neilmc/
Posts: 306 |
Thats great info. I'm gonna keep it in my glove box as a back-up since I usually leave my haynes manual in my bathroom.
98 Contour GL V6
Current Mods: Mud Flaps
Posts: 462 |
Originally posted by Blubsy1979: Thats great info. I'm gonna keep it in my glove box as a back-up since I usually leave my haynes manual in my bathroom. Remind me not to borrow your manual...
Posts: 1,051 |
Originally posted by wjang: [B]CONTOUR ESSENTIAL INFORMATION
Fuel tank 61.5 liter (16.2 gallons) B] The O.M. for my 2000 states the fuel tank capacity is 15.4 gallons (58.5 litres). Was there a change from 1998?
P.M. Summer -- simul justus et peccator
2000 SVTour Silver Frost 374/2150 -- #9669 of 11445 total run Blaupunkt Heidelberg with A08 Changer and RC-09 remote, Boston Acoustics, K&N, Mobil 1 and Cobra R Mobil 1 "Factory Fill" plate, 35% metallicized tint, high beams in the lows, Bill Jenkins' "off color" floor mats, and custom "koozie" cupholder (pics soon!) 96 Sable ZZZ (wife's)
Historic Ownership: 42 Dodge Powerwagon Munitions Carrier, 59 Morris Minor, 64 TBird, 69 BMW 2002 Blue Dot, 72 German Ford Mk I Capri V6, 76 Honda Accord, 82 VW Scirocco, 88 VW Jetta, 91 Ford Escort GT, 98 Countour SE Sport V6 ATX
Cars I want: Lotus Elan S2, Austin Healy Sprite Mk I, my old BMW 2002 back.
If you think this sig is long, you oughta see my undergraduate transcripts!
Posts: 7,329 |
Originally posted by NMC: Excellent except that Ford and most people here have revised the lug nut torque to 90 lb-ft. Ford Service CD's states 90-100 lb/ft 68 is far too little...
