#43436 07/26/02 03:40 PM
drsvt Offline OP
Was wondering if anybody has done this on their SVT UIM any luck or horror stories, or pics...or how about powder coating
#43437 07/26/02 03:45 PM
You can see my web page... Jet Hot Coated the Upper Intake Manifold, Cold Air Intake pipe, Y-Pipe and Cat.
Why would you take the time to powder coat just for looks when you can also have it functional?
Jet Hot will Drop temps about 25-30% (Claimed).
Silver 98 SVT Contour E0
#4124 (Currently on Life Support)
Built 11/97 Bought 1/98
Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods
Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI
"Come Out...Come Out Where Ever You Are"
http://www.geocities.com/speeddemons19
#43438 07/26/02 04:45 PM
Powder coating is 10 times more chip resistant than paint. laugh BNM powdercoating link.
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
#43439 07/26/02 05:28 PM
Hey BNOON, you just keep following me dont you? ha ha smile
Ive seen your work, Excellent.
If I ever need powder coating Ill be coming your way. Just in the middle of an expensive 3.0L swap.
#43440 07/26/02 06:16 PM
painting and powedering insulate heat...so it doesnt disapate as fast. get someone who can polish and make it a nice shinny hunk of aluminum
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill|
Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
#43441 07/26/02 06:27 PM
Originally posted by jiako:
painting and powedering insulate heat...so it doesnt disapate as fast...
That's exactly why you should paint or coat it with something, so that it doesn't absorb heat from the surrounding air and transferr it into the UIM. Especially the underside...
Brad Noon
'99 SE MTX
#43442 07/26/02 07:52 PM
JET-HOT protects steel over 140 times longer than high-temperature paint, more than 14 times longer than chrome and more than 5 times longer than first-generation metallic-ceramic coatings.
Here is an example of a Header that is Jet Hot coated:
Temperature Comparison:
Corrosion Comparison:
#43443 07/29/02 01:20 PM
I remember an old pic of a chromed UIM, perhaps Micah had it. confused
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
