Posts: 417 |
Anyone have a sound clip of this? I would like to know, because today I got an SVT rear bumper, and I would like to run the propor exhaust through it, so I wanted to go the cheepest route, and just run straight pipes out the back with no mufflers, but keep the resonator, I wanted to know if this "mod" would be way ungodly loud or if it would sound "raspy" or if it would just sound simply awesome.
Thanks hope someone's got this!!
99 Ford Contour SE Sport Manual V6 SVT front/ rear bumper /w Aussie grille Jet black Premier DEH-P740MP head unit matrix display, plays Mp3s!! 800 watt Kenwood amp 2 12" Polk Audio subs Blue "euro" headlights Eibach Pro-Kit springs 17" Enkei RS-5 White Indiglow gages
Posts: 3,421 |
I have heard this seup 1st hand on 2 Svts and i must say it sounds awsome. Sorry i dont have a clip.
Posts: 256 |
I'd really like to hear this too.
Posts: 3,237 |
Rasp-city, in the county of Dronesville, in the state of Annoying!
Posts: 647 |
I had this setup on my SVT and I loved it. The ONLY rasp is when it?s cold, after a mile or two you are good to go. I would not hesitate to spend the $40.00 it costs to have this done. All I have is the in-car of the setup: Stock SVT Exhaust, No Res, KKM
Posts: 1,210 |
By all means do it! I have the exact setup on my SVT, and it sounds great. And yes, it is a bit raspy when cold. When those pipes warm up, it sounds fat!
Posts: 417 |
Now, will it sound the same with no mufflers at the end and a resonator in the middle?? I see your sound clip is "backwards" (no resonator, but you do have mufflers).
Posts: 3,421 |
Originally posted by mmarfan: Now, will it sound the same with no mufflers at the end and a resonator in the middle?? I see your sound clip is "backwards" (no resonator, but you do have mufflers). Yes it will sound differnt.
Posts: 2,148 |
I had straight pipes for a while with a bullet resonator and resonated tips....the thing wailed...sounded awesome...but was a cop magnent not a chick magnent...best exhaust I've heard on these things is magnaflow...but that's not cheap...
Former owner of 1999 SVT Contour #555
Posts: 4,476 |
i just did the Edelbrock Resonator (part #5542) and it's MUCH louder than stock, AND I left the mufflers ON... all depends on your tolerance levels... but hey, I'm 32 years old too! i used to have a v-8 with glasspacks exiting just in front of the rear wheels - now THAT was FUN!
Todd Christ SVT Contour Registry MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator '98 E0 SVT Contour #1037 of 6535
