Administrator
Administrator
http://www.jag-lovers.org/brochures/new_s_type/s_99uk_40_l.jpg
Check out that CRAZY oil pan!
I can't tell if it has the DMD, either.
That black cam cover seems to be plastic.
Also, I have no idea what goes on that hole on the top of the UIM. Some kind of selenoid for a butterfly valve?
And, UIM is metal while the LIM is plastic! Looks like it would insulate the UIM from heat fairly well.
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
Ray Offline
Wow.. you are right! VERY nice..
I am stumped to the hole, but will likely reside in your theory.
I think it has the DMD, but wouldn't be ab;e to tell from that picture, either..
Hopefully more pics of these beauties come out, soon!
Ray
Check out my car!! (Profile Registry)
Have a Nextel two-way? check out my registry for my number!
Ray Haralson
Jacksonville, FL
s_r_haralson@sar.med.navy.mil
srh@texas.net
YIM: midnghtflm
AIM: midnghtflm
NEWEST MOD: a BEAUTIFUL girlfriend for my one and only passenger.
Do you know how much HP that's throwing?
99 Ford Contour SE Sport
Manual V6
SVT front/ rear bumper /w Aussie grille
Jet black
Premier DEH-P740MP head unit
matrix display, plays Mp3s!!
800 watt Kenwood amp
2 12" Polk Audio subs
Blue "euro" headlights
Eibach Pro-Kit springs
17" Enkei RS-5
White Indiglow gages
In S-Type 240 HP. In X-type 231 HP. I read it was going up to 250 HP or so, this year or next. And, a supercharged version is in the works..
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
Kanuter (can-ooo-ter) valve... laugh
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
Lee Offline
I think they used plastic on the other valve cover to elliminate a radiant heat source from under the intake.
The box on the front of the oil pan looks to be where the pickup is so it probably helped in getting more oil to the system quickly, but would definitely interfer with the Contour subframe.
I think I finally see what Terry is talking about with the direct acting buckets. There aren't any lifter arms etc.
The waterpump is cam gear driven on the front and for our use the cam cover would have to be changed along with the oil pan. An eletric Waterpump is a must. The only question this brings up is are the 3.0 blocks universal so that there are provisions for rear pump and front pump? Cover plates etc?
The lower intake looks exactly the same as my 3.0 Taurus peice, at least from what I can see.
Ideal setup (Non-boost):
Jag Long block
ST220 UIM
Taurus LIM
24Lbs. Injectors
2.5 Valve covers (if they work?)
2.5 SVT Oil Pan
2.5 Timing chain cover
DMD if not already present.
Lee Cox
In life begins responsability...
Project Car
Oil filter doesn't seem to be in the "traditional" location either.
TB
Tony Boner
Administrator
Administrator
Originally posted by bnoon:
[b]Also, I have no idea what goes on that hole on the top of the UIM.
Kanuter (can-ooo-ter) valve... laugh [/b]
Is that for connecting and disconnecting the two runner tanks?
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
