Posts: 1,355 |
Simon W. Las Vegas. 96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!) 1999 SVT Engine SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT "it's only nuts and bolts" - Terry Haines "Drive it like you stole it" - Me!
Posts: 1,559 |
Simon it looks good! did you ever figure out away around the PATS problem other than using the old PCM?
Posts: 1,355 |
No, I'm just going to use my stock SE one which should be fine. I have talked alot with others who are running 3L on their stock SE computer with 24lb injectors (bnoon) etc so I think mine will be fine. I'll probably loose about 5hp from not using it, no biggy.
Posts: 3,066 |
heatsoak! Lookin good man! Have ya had any problems or pitfalls so far? Why not go the 3.0 route as long as you are swappin?
STD's are like Pokemon... Gotta catch em' all!
Posts: 1,355 |
lol...I was going to go 3L but a few things kept me from going that way, one of which being money. I wanted the best improvment over stock that I could get with less hastle. So the SVT engine was it. I don't have enough knowledge of engine internals to be pulling them apart and swapping out heads, cams, shot blocks, LIM, injectors etc etc etc. Regarding the filter, it will actually sit just below the fans (I measured it), so I think it's not going to get any more heatsoak then it would being in stock position up top. But we'll see.
Posts: 1,003 |
Did you preform the mystery mod on the manifolds before you bolted them on? Perfect time to do it for a nice gain in performance...
Posts: 1,355 |
No I haven't gutted the pre-cats. Don't now how!..lol. Yes I read the How-to on it but it confused the crap out of me and I don't want to screw something up.
Haven't had any major pitfalls/problems (yet). Everythig has been pretty much straight forward. Only real hard part was 1. getting the trans back onto the engine on my own! and 2. getting everything aligned on the subframe was a bit of a PITA. That took a while.
Posts: 108 |
Keeps your mind of the wedding, eh buddy?
See you in a few weeks!
"Even a clock that doesn't work is right twice a day" Hemlock54@hotmail.com
Posts: 91 |
Simon,
I'm curious because I've never pulled an engine. Where do you connect the hooks from the lift to the engine? Are there loops on the engine itself? Is there some sort of wire basket going around the engine to hook on to? I just can't picture it or see it in yours. It also looks balanced pretty well on the lift. How did you do it?
Late
JE
Posts: 1,355 |
Originally posted by Hemlock: Keeps your mind of the wedding, eh buddy?
See you in a few weeks! Haha...yeah really!! Beth was freaking out today saying how it's only 2 1/2 weeks away. It feels like months to me.  See you soon bud! John: The engine has two metal "loops" actually attached to the engine. 1 is at the back on the left (lookng that the front of the engine, you can see it on the 3rd pic, just follow the chain down) and the other is front right. You can see the front one in the first few pics (the chrome chain/hook is attached to that one). These are the actualy "engine hoist points" on the V6 engine. The engine is actually sitting on the engine hoist's "legs". It makes it alot easier that way as I can move the hoist around (its on wheels) with the subframe/engine/trans sitting in them very easily.
